the shorter the coax the better..
Not according to the experts at the CB shop I deal with, the COAX should be 15' long. That being said I mounted my antenna in the middle of my roof and the CB is mounted on the x-bars of my cage.
I am no expert on the subject, and there is certainly a great deal of science here, but I believe antennas are tuned to a specific cable length. Check the package for a recommended cable length. The small adjustment at the end of the cable is only for variances in how/where the antenna is mounted AFAIK. It isn't intended to account for large differences in cable length.I remember my 4' antenna called for a 15' cable but the store I was at only had a 12' cable and as a result my SWRs are higher than I'd like. I've been needing to purchase a longer/proper 15' cable but its such a low priority on my TO-DO list.SloCrawler, I haven't read that link yet but I'm willing to bet its discussing 1/2 the distance of our radio's wavelength. I think a shorter cable is ideal, but the long lengths of our antennas (usually five+ feet) requires a longer cable?At the very least, if you use a long cable and have left over cable length, be sure to roll up the extra length in as large of an area as possible to prevent induction (if you wrap a wire up into a coil, it will generate a small magnetic field that will affect the voltage passing through the coil). My radio is mounted only a few feet from my antenna, so what I did was I ran the extra 8~10-feet of unused cable length back-and-forth at the back of my cab under my carpet from the drivers-side-to-the-passengers-side a few times with as much straight-lenght-sections as possible to minimize any opportunities for a magnetic field to generate.BigMike
Just some tech I got from a local expert, he said dual antennas are only benificial if mounted minimal of 9' apart. He also told me long coax cables are generally for big rigs with a trailor. Its not better to have long cables but much easier to tune. With this info he also told me a 8' cables should work best for my setup with only one firestike.
Started by JonnyM Parts Wanted
Started by kneedownnate Parts For Sale
Started by cen-cal crawler Toyota Pickup/4Runner Tech 1979-95
Started by cen-cal crawler Parts For Sale
Started by BigMike Newbie Questions
