Author Topic: Big master cylinder, small caliper?  (Read 3450 times)
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« on: Jun 27, 2011, 11:38:31 PM »
Ok so I have a fj80 master cylinder I want to put in my sased 94, but it has the factory solid axle brakes and I don't have the money to upgrade that right now. So will the calipers take the extra pressure from the bigger master? Are there any problems I'll run into doing this?
RockRescue
  • Member since Feb '06
Re: Big master cylinder, small caliper?
« Reply #1 on: Jun 28, 2011, 12:01:37 AM »
i just did this exact swap   and when i did it  i had a very stiff pedal  i  drove around for a day and swapped back
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #2 on: Jun 28, 2011, 12:41:38 AM »
Big master, small calipers = less pressure at the calipers...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
HIvoltgeToy
  • Turtle Points: 2
  • Male Posts: 127
  • Member since Jul '10
« Reply #3 on: Jun 28, 2011, 01:37:08 PM »
If you don't like a stiff pedal you should get a dual diaphragm booster. I think the bigger mc should work fine. Look at the brake write up on the pirate Toyota bible.
IBEW Local 1116
RockRescue
« Reply #4 on: Jun 28, 2011, 01:56:12 PM »
My guess is  the pedal would not be stiff if i swapped to the ifs rotars and calipers .   I can read every page on PBB and it will not change the fact that  my pedal was stiff.   when i install the ifs rotars   i will swap the MC back   and see how it does .
HIvoltgeToy
  • Turtle Points: 2
  • Male Posts: 127
« Reply #5 on: Jun 28, 2011, 02:18:01 PM »
I have a 1 inch bore mc off a V6 4runner, V6 calipers, and vented rotors. Mine pedal is really stiff. I'm a big guy and I have to push hard just to come to a slow rolling stop. I was referring to the pbb topic about upgrading to the dual diaphragm booster. It's suppose to help a lot with a bigger mc.
IBEW Local 1116
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« Reply #6 on: Jun 28, 2011, 03:15:29 PM »
I ran a fj80 master cylinder with stock 85 small calipers for almost 8 years before getting a dual diaphram booster.  brakes were a bit stiff, but not bad.  the dual diaphram booster will definitley make a world of difference.  i was going to upgrade to the ifs calipers and bigger rotors, but after the booster swap, i'm going to leave it alone.  it stops no problem. with hardly any pressure with one foot, it stops like new car
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
sabatoa1
  • Male Posts: 396
  • Member since Jan '10
« Reply #7 on: Jun 28, 2011, 03:24:24 PM »
What years did the dual diaphram booster come on?
1984 4runner buggy 22r on pane, duals, hydro assist, spool front, spool rear, 37x13x16 Creepy Crawlers.
http://board.marlincrawler.com/index.php?topic=89989.0
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
« Reply #8 on: Jun 28, 2011, 03:28:02 PM »
not sure.  i got mine from a 1990 ext pickup with a 3.0 in it.  I think all the 3rd gen trucks, and 2 gen 4runners have them.  don't quote me on that though.
ABD Motorsports
#4475
KK6QDW
HIvoltgeToy
  • Turtle Points: 2
  • Male Posts: 127
« Reply #9 on: Jun 28, 2011, 06:28:16 PM »
I think V6 trucks and 4runners have them. I think some people use T100 boosters. And maybe some others.
IBEW Local 1116
HIvoltgeToy
  • Turtle Points: 2
  • Male Posts: 127
« Reply #10 on: Jun 28, 2011, 06:30:40 PM »
If your at a junk yard I think they are 1" fatter than a single. But I'm not a 100%. If you search here or pirate you can find out for sure.
IBEW Local 1116
Nimyad [OP]
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #11 on: Jun 28, 2011, 09:39:15 PM »
So shouldn't my 94 22re have that booster?
87uglyrunner
  • Turtle Points: 3
  • Member since Apr '11
« Reply #12 on: Jul 02, 2011, 11:15:10 PM »
I'm doing the same thingon my 87 runner, I dont have all my parts to rebuild my solid front axle so im using the v6 brake booster. and I have the stock ifs width axle in back. the brakes feel pretty good to me? I'm going to upgrade to fj rotors and ifs calipers soon as i get money to rebuild the whole axle. if you ask me you can drive it around for a while till some more cash comes your way!
loctupdave
  • Turtle Points: 5
« Reply #13 on: Jul 11, 2011, 10:12:24 AM »
I hope more chime in on this I just finished this mod. V6 calipers, booster and master cylinder on a straight axle with ifs hubs and vented rotors. Also solid rotor disk brakes on the rear axle.
« Last Edit: Jul 11, 2011, 10:18:53 AM by dngspot »
A real man builds it... Then his wife points out all that he did wrong.
mrtt999
  • Male Posts: 26
  • Member since Feb '11
« Reply #14 on: Oct 18, 2011, 11:22:01 AM »
My old master cylinder is leaking like a sieve on my '84 with stock brakes.  It cleaned the paint up nicely on the firewall.   :ack:  I am replacing it with an FJ80 master and T100 booster.  I am dreading the brake bleeding by myself ...   :crossed:  Does anyone have any one-man brake bleeding tips/tricks?
sabatoa1
  • Male Posts: 396
« Reply #15 on: Oct 18, 2011, 12:40:48 PM »
Get a full brake bottle and put a hole in the top get a tube that will fit on brake bleeder open and pump until air is gone.
Last post Feb 12, 2007, 08:03:55 PM
by 79coyotefrg
Last post Mar 08, 2007, 08:46:31 AM
by fordh8r
Last post Oct 23, 2007, 01:40:50 AM
by THK Matt
Last post May 27, 2008, 10:13:35 PM
by Black Runner
Last post Dec 28, 2009, 11:55:29 AM
by junya92toy
