Author Topic: Koyo CV U-joints for '85 drive shaft??  (Read 7979 times)
spc mike
  • Male Posts: 428
  • Member since Apr '08
« on: Jun 19, 2011, 03:34:01 AM »
I remember seeing them available on a web site a while ago but cant' find it. So does anyone know where i can find the Koyo replacement U joints for the double cardan joint on my '85 drive shaft?? Does anyone sell the Koyo u-joints in Fresno?? Thanks in advance!
spc mike [OP]
  • Male Posts: 428
Re: Koyo CV U-joints for '85 drive shaft??
« Reply #1 on: Jun 19, 2011, 10:49:08 PM »
bump...anyone know??
Dingman.
  • Turtle Points: 1125
  • Male Posts: 3,448
  • Member since Oct '08
« Reply #2 on: Jun 19, 2011, 11:49:59 PM »
We sell matsuba (sp?) Ones at work.
Made in japan
http://highangledriveline.com/toy.html
spc mike [OP]
  • Male Posts: 428
« Reply #3 on: Jun 20, 2011, 12:36:27 PM »
Ya those Matsuba U joints should work! do you know the part number for the ones that fit into to CV side of the drive shaft?
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #4 on: Jun 20, 2011, 12:38:58 PM »
Don't tell everyone, but Matsuba makes the U-Joints for Koyo.  Shhhhhh !
Dingman.
  • Male Posts: 3,448
« Reply #5 on: Jun 20, 2011, 12:58:14 PM »
Unsure on the part numbers, we do sell them though
spc mike [OP]
  • Male Posts: 428
« Reply #6 on: Jun 20, 2011, 01:12:07 PM »
Nice! you work for high angle?? Can i call and order just a couple joints?
I take it these are the same.....
http://www.lowrangeoffroad.com/index.php/catalogsearch/result/?q=matsuba+joint
spc mike [OP]
  • Male Posts: 428
« Reply #7 on: Jun 20, 2011, 01:50:09 PM »
Alright..i called high angle and they don't have any of the CV side Matsuba joints in stock and wont have any till the end of the month. However i called Low Range and they said that their Matsuba joint will fit the CV side BUT....... High angle says the Matsuba part number UJ-236 (that they are out of) was the right part number however when i called Low Range Off Road they told me That their Matsuba UJ-238 would fit the CV joint too?!?! So i call High Angle back again and he said that UJ-238 was not what i need and don't wast your money on it.......so Anybody else know for sure??
Dingman.
  • Male Posts: 3,448
« Reply #8 on: Jun 20, 2011, 01:55:47 PM »
Jesse knows what he is talking about.
spc mike [OP]
  • Male Posts: 428
« Reply #9 on: Jun 20, 2011, 01:58:10 PM »
Ya, he definitely sounded WAY more competent than the guy i talked to at Low Range. So it looks like i got to go dealer because i need them asap.
86rustbucket
  • Turtle Points: 45
  • Member since Jun '09
    • Buy me a soda
« Reply #10 on: Jun 20, 2011, 02:19:58 PM »
Brendan down at marlins shop told me the ones in the cv are not available anywhere.
He said just keep them greased, and start looking for another shaft if they go out.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #11 on: Jun 20, 2011, 03:24:29 PM »
You can get replacement joints for the CV at NAPA, not the best in the world but better then nothing. This place also sells but I do not know the brand, the have all the parts for the CV.  http://www.rockforddriveline.com/toyota.pdf
Low Range does not know what they are talking about, they are different, trust what High Angle says, they know d-shafts.
spc mike [OP]
  • Male Posts: 428
« Reply #12 on: Jun 20, 2011, 03:24:37 PM »
Ya that's what i am finding out with the exception of the one that High angle sells....BTW Brandon, i still need to pick up that front DS from you when the time is right. You still got it?
ALSO was wondering if you guys thought a non clearanced CV out of a post 85' truck would work good on the rear Drive Shaft considering i am only gonna have around 3 inches of lift and the rear doesn't droop as much as the front cause the pinion is centered in the axle. Does anybody run one? Opinions? I JUST DON'T WANT TO RIP APART A PERFECTLY GOOD CV TO CLEARANCE IT AND THEN TO PROBABLY MESS IT UP...ESPECIALLY IF ITS NOT NECESSARY.
OOPS
  • Male Posts: 2,561
« Reply #13 on: Jun 20, 2011, 03:29:46 PM »
From what I have been told you do not need to clearence it, but I always do.
spc mike [OP]
  • Male Posts: 428
« Reply #14 on: Jun 20, 2011, 03:41:58 PM »
Thanks OOPS, ya i went to Napa right after my trip to the dealer and they did have one that was for the CV available but didn't have them in stock and i think the Manufacture of orgin was china too.  :thumbdown:
86rustbucket
  • Turtle Points: 45
    • Buy me a soda
« Reply #15 on: Jun 20, 2011, 05:07:02 PM »
Ya I still have it sittng there with the runner shafts.  Just let me know when you need them.
And I ran an 86 cv on my rear with no issues, and my truck was setup pretty similar to yours, about 3 inch lift and dual cases on a standard cab 2nd gen.
Dingman.
  • Male Posts: 3,448
« Reply #16 on: Jun 20, 2011, 05:30:32 PM »
Its amazing to see the difference between a home clearance job and how jesse does it at work. Lol
OOPS
  • Male Posts: 2,561
« Reply #17 on: Jun 21, 2011, 10:28:58 PM »
I know that Jesse does beautful work and he has the machines to do it. Most DIY people do not have the machines so we deal with it with what we have to work with. Mine may not be pretty, but I am getting forty one degrees out of it. I build what I can and pay for what I cannot build.
Last post Mar 12, 2007, 07:42:05 AM
by MiniSimp
Last post Aug 19, 2010, 10:17:56 AM
by cen-cal crawler
Last post Jan 26, 2011, 08:14:28 PM
by BigMike
Last post Aug 26, 2015, 04:34:13 AM
by Ritchie
Last post Jun 10, 2015, 04:56:10 AM
by Ritchie
