Author Topic: 4.7 GEARS IN FRONT OR REAR CASE ANF WHY?  (Read 2178 times)
Greencorey
  • Turtle Points: 4
  • Male Posts: 38
  • Member since Aug '05
« on: Apr 13, 2011, 11:09:22 AM »
Why is it recomended to put the 4.7 gears in the rear case. I have friends with the gears in the front case and no problems.  :help:
"If you don't live for something you'll die for nothing"
-Hatebreed
toe
  • Turtle Points: -60
  • Male Posts: 1,693
  • Member since Dec '09
Re: 4.7 GEARS IN FRONT OR REAR CASE ANF WHY?
« Reply #1 on: Apr 13, 2011, 11:14:20 AM »
BECAUSE
WE SAY SO
 :turtle3:
Me
Greencorey [OP]
  • Turtle Points: 4
  • Male Posts: 38
« Reply #2 on: Apr 13, 2011, 11:26:52 AM »
So you mean I need blinker fluid to finish the job.
-Hatebreed
toe
  • Male Posts: 1,693
« Reply #3 on: Apr 13, 2011, 12:11:58 PM »
22Rs don't need the blinker fluid
Me
GNasty 82
  • Turtle Points: 994
  • Male Posts: 206
  • Member since Nov '09
  • Get Nasty!!!
« Reply #4 on: Apr 13, 2011, 12:12:56 PM »
The reason is because the output from the crawl box (in low range) has multiplied the torque going into the rear case.  If you have 2.28 gears in front, it's less torque being applied to the rear case input than when you have 4.7 gears in front.  Less torque on the rear input means less chance of breaking any of the rear case's components.
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
Rocksnail
  • Turtle Points: 3
  • Male Posts: 595
« Reply #5 on: Apr 13, 2011, 12:30:49 PM »
Gnasty82 is right. If the 4.7s are in the crawl box it will put to much torque to the 2.28 rear case. You would be more prone to braking output shafts.
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
Greencorey [OP]
  • Turtle Points: 4
  • Male Posts: 38
« Reply #6 on: Apr 13, 2011, 12:36:41 PM »
Excellent answer :beerchug: Makes a ton of sense.
-Hatebreed
Greencorey [OP]
  • Turtle Points: 4
  • Male Posts: 38
« Reply #7 on: Apr 13, 2011, 01:01:14 PM »
http://kalecoauto.com/index.php?main_page=product_info&cPath=2&products_id=6
Best Blinker fluid on the market. Works on all imports and domstics.  :moon:
« Last Edit: Apr 13, 2011, 01:10:23 PM by Greencorey »
-Hatebreed
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #8 on: Apr 14, 2011, 02:47:18 AM »
GNasty 82 hit the nail on the head, you can twist a 2.28 shaft if it is in the rear. That reminds me I need to rotate my blinker fluid and change the winter air in my tires to summer air.
Last post Nov 22, 2004, 01:23:14 PM
by Drachota
Last post Feb 07, 2005, 09:48:00 PM
by sandboxtoy
Last post Feb 19, 2006, 11:58:43 AM
by ToYocRawleR
Last post Feb 19, 2008, 12:43:47 PM
by 82rustbeast
Last post Apr 23, 2015, 01:05:03 PM
by lamkinranch
