Author Topic: whats the best diff locker?  (Read 2652 times)
TheMuddyHilux
  • Male Posts: 3
  • Member since Apr '11
« on: Apr 07, 2011, 01:26:00 AM »
i have a '82' LN46 hilux,raised prity high,35inch tyres,supra engine.its my daily driver but i want to get diff lockers front and rear.since its my daily i was thinking air lockers but i just wanted to see what other 4x4ers do.being in new zealand my options are only realy aussie lockers,arb airs or a detroit style 1 which i forgot the name of.
cheers  :beerchug:
toyota41180
  • Turtle Points: -1
  • Male Posts: 66
  • Member since Feb '10
Re: whats the best diff locker?
« Reply #1 on: Apr 07, 2011, 06:22:00 AM »
ARB it is open until you need to use it and then full spool
It will save on tires in the long run
Dog is man's best friend. If you don't believe me lock your wife and your dog in the trunk for an hour and when you open it see which one is truly happy to c.u.
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #2 on: Apr 07, 2011, 07:07:10 AM »
get the full detroit... no pesky airlines to snag or leak.....
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #3 on: Apr 07, 2011, 10:14:45 AM »
x2. i like detroits. strong and mechanical. and welcome to the  :turtle: board!
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #4 on: Apr 07, 2011, 11:19:46 AM »
For reliability the Detroit is the way to go.
Quote
blackdiamond
  • Turtle Points: 1174
  • Male Posts: 5,059
  • Member since Dec '03
  • Crawlin with Marlin
« Reply #5 on: Apr 07, 2011, 11:33:09 AM »
I really doubt that having an ARB would save enough money in tires to pay for itself for a long time, but you might get a slightly better wear pattern and thus a smoother ride for a little longer.
The ARB would be the best in an ideal world, but a Detroit is much more reliable.  If you drive on the street in snow then you might consider an ARB in the front only to minimize cost.  Street driving on snow with a mechanical locker is an interesting adventure that borders on being unsafe.  There's a fine line between going to fast in 4wd to be safe but not wanting to go for it in 2wd.
94MtnYote
  • Turtle Points: 6
  • Member since Oct '07
  • - 94 std cab-
« Reply #6 on: Apr 07, 2011, 12:30:05 PM »
The Yukon grizzly locker (similar to the Detroit)  looks pretty trick too.
 Marlin 1200LB clutch
TheMuddyHilux [OP]
  • Male Posts: 3
« Reply #7 on: Apr 07, 2011, 05:02:52 PM »
thanks for that guys.the yukon looks good ae.i agree with the arb being money saving in the long run but its a big price to fork out in the begining,and you do have alot of components to go with it.another 1 i saw on the net used a power operated loking mechanism,when as power is aplied it spreads the locking side gears into each other.not too good when you want to crawl through mud or somthing but need the locked axle.ill look into shiping costs to get a cuple of yukons to new zealand
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #8 on: Apr 07, 2011, 06:14:36 PM »
Fourteem years on the air line to the rear, eleven on the front. No sagging, no leaking. If you route them you will have no problems with them. ARB is the only locker I would own.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #9 on: Apr 07, 2011, 07:07:48 PM »
do your resurch on E-lockers
they come in some stock tacomas and runners
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
« Reply #10 on: Apr 07, 2011, 10:15:55 PM »
 :yesnod:
Last post Mar 25, 2006, 05:18:03 PM
by scyota
Last post Mar 23, 2006, 11:02:09 PM
by bustatoy
Last post May 29, 2006, 09:36:47 AM
by blackdiamond
Last post May 23, 2007, 11:14:43 PM
by crawler925
Last post Apr 02, 2011, 08:59:27 AM
by brainlessfool
