Author Topic: I need some opinions  (Read 1028 times)
David
  • Turtle Points: 218
  • Male Posts: 263
  • Member since Jan '03
  • I love Marlin Crawler!
« on: Feb 28, 2011, 05:24:13 PM »
 Bought an engine that supposedly had about 10,000 miles on it (83 22r). Installed it in my 83 and from the time it fired up it smoked out the pvc hole in the valve cover and the vent hose at the front of the cover. Blue smoke would billow out from those two places and it never stopped even after warm up. After a short time at idle hitting the gas would produce a cloud of smoke from the exhaust.
Figured it would be the head with that much smoke, valve seals etc.. Took my old head to the shop and had a complete rebuild done. Took the head off of the 'new' engine and it does not look bad, looking into the intake holes and using a q-tip I find very little oil on the valve or stems The up side of the head is very clean and appears to have had work done on it. Head is coated with a thick coating of burned oil at each dome, plugs are all oil fouled.
The pistons are also covered with an even thicker coating of burned oil. A pretty heavy ridge is at the top of each cyl. and the pistons seem almost loose in the cyl, 20-25 thou. side to side.
I'm thinking I should just take the darn thing out and rebuild my old motor and chalk it up to experience, buyer beware and all that.
What do you guys think??
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
Re: I need some opinions
« Reply #1 on: Feb 28, 2011, 05:43:39 PM »
Does it have room to be bored or is the block maxed out? If ya can't rebuild the bottom end do like that Discount Tire commercial and throw it through the guys window.
Sucks, hope ya get it going.
David [OP]
  • Male Posts: 263
« Reply #2 on: Feb 28, 2011, 07:40:23 PM »
Haven't mic'd the bore on this engine yet. Looking further tonight I found that three of the water jacket holes from block to head were blocked off in the block with some sort of sealant so I'm just going to pull it out and rebuild the original engine.
Last post May 22, 2004, 09:31:09 PM
by Hyena
Last post Jan 29, 2005, 06:33:47 PM
by Skinny_Pedal
Last post Feb 11, 2005, 10:35:05 AM
by BLUCRUZ
Last post Dec 20, 2009, 11:46:38 AM
by NCK4L
Last post Oct 21, 2011, 03:16:17 PM
by BadnewsBob
