Author Topic: engine parts and stuff!!  (Read 1566 times)
blackxlava
  • Trade Count: (0)
  • Turtle Points: -1
  • Member since Jul '07
« on: Feb 13, 2011, 05:28:08 PM »
all parts are for 20r/22r/22re engines found in early pickups, 4runners, also some celicas
Pacesetter header long tube.....$150
offenhauser intake 4 barrel for Holley 22r style runners....$200
offenhauser intake c series 2 barrel for Weber carb, 32/36 or 38 22r style runners... $150
front drive shafts $40
rear drive shaft $60
transmission 5 speed $100
transmission 4 speed bad second gear $50
forward shift transfer case $100
shifter sticks. $10
starters ...$50
radiators (new) $50
a/c system from 20r, complete minus condenser. (engine side)
20r long block, ran when pulled make offer
stock 20r intake$35
alternator from pre 84 with external regulator
alternator from 85+
water pump (new)
timing chain covers
distributors (vacuum advance)
stock 20r carb
stock 20r pollution pump and egr stuff
22r longblock, early block pre 84, has 2 bent valves, still ran just had a slight miss, have a head casting that can go with it for the valves
22re short block (85+)
22re long block, new cylinder head, has LC Engineering single row adjustable cam gear, LC Engineering cam, .450 circle track cam,  LC Engineering egr block off plate, fuel pump block off plates, was told bottom end was rebuilt, but not sure. ran when pulled 3 months ago. will part out with enough interest.
valve covers(22re later style)
power steering pump and reservoir
coolant pipes $20
flywheels and clutches
complete a/c heater core box from under dash with blower motor and cable controls.
a/c dash vents
84 cali. emissions computer for 22r
entire dash board
i think that's about it, but if your looking for something and its not listed, ask i might have one!
everything is make an offer, i just want to get this stuff out of my shop! if you want something but you think the price is to high make an offer!!
buyer pays shipping
all located in 78411 for shipping
« Last Edit: Feb 15, 2011, 05:18:31 PM by blackxlava »
blackxlava [OP]
  • Trade Count: (0)
  • Turtle Points: -1
Re: engine parts and stuff!!
« Reply #1 on: Feb 13, 2011, 05:47:02 PM »
Do you have a high pinion for sale?
no axle or steering stuff as of yet, if i turn one up ill let you know
donburks
  • Trade Count: (0)
  • Member since Jan '11
« Reply #2 on: Feb 21, 2011, 01:21:25 PM »
I need a 20r or 22r block (for my 20r head) or complete long block.  I see  you have a 22r with bent valves (how did valves get bent?).
How much for each or any other blocks you might have that is not listed?
Thanks,
Don
boomtacoma01
  • Trade Count: (0)
  • Turtle Points: -68
  • Male Posts: 321
  • Member since Feb '10
« Reply #3 on: Mar 21, 2011, 02:11:49 PM »
Interested in the alternator for the 85, valve cover for the 22RE and the shifter sticks.
PM on the Way
IG @boomtacoma01
runr-meech
  • Trade Count: (0)
  • Male Posts: 354
  • Member since Dec '09
« Reply #4 on: Mar 26, 2011, 10:53:20 PM »
what do you want for the 22re ? short block - long block ? location?
88 4runner
Last post Aug 15, 2005, 07:17:43 PM
by trevinotrek
Last post Oct 16, 2005, 02:48:44 PM
by 83rocktoy
Last post May 13, 2009, 09:10:20 AM
by superyota
Last post Dec 05, 2009, 11:54:03 AM
by Dingman.
Last post Mar 23, 2011, 09:51:02 AM
by ToYocRawleR
