Author Topic: carb problems  (Read 3695 times)
motoracer
  • Turtle Points: 12
  • Male Posts: 319
  • Member since Sep '07
  • my geen bean
carb problems
« on: Jan 28, 2011, 03:42:42 PM »
got my fuel lines run correctly. i think ive got my vacuum  lines run right. so heres what its doing. its idling ruff,its suging  when it hits 2000 rpm gos up and down from 2000 to 2100 rpm but clears up at higher rpm and also clears up  below 2000rpm. and my fuel pump is dumping a lot of fuel tru the return line.. so please help anybody   :hammerhead:
pie
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: carb problems
« Reply #1 on: Jan 28, 2011, 03:57:22 PM »
Something may be stuck in the needle valve.
You might be able to flush it out by pinching off the fuel line to the carb; then just as the engine starts to die, releasing the pinch............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #2 on: Jan 28, 2011, 04:08:23 PM »
ok ill try it . see what happens
pie
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #3 on: Jan 28, 2011, 07:07:14 PM »
didnt fix the problem . should they be a lot of gas coming from the return side of the fuel pump?
pie
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #4 on: Jan 31, 2011, 02:27:36 PM »
anybody  help
pie
83 Crawler
  • Turtle Points: -13
  • Male Posts: 2,779
  • Member since Jun '09
Re: carb problems
« Reply #5 on: Jan 31, 2011, 02:32:12 PM »
propane or efi  :thumbs: thats what im going to do
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
Re: carb problems
« Reply #6 on: Jan 31, 2011, 06:08:10 PM »
Rebuild it! Whe I took mine apart I found all kind of cool things the previous owner did that made the carb run just like that...
I wouldn't worry about the return line, it's doing what it's suposed to and you are getting fuel to the carb.
– Steve McQueen
81_yota
  • Turtle Points: -41
  • Male Posts: 299
  • Member since Apr '10
  • Parcore !
Re: carb problems
« Reply #7 on: Jan 31, 2011, 06:42:28 PM »
i would try rebuilding it and make sure u clean any small ports out with thin wire and carb cleaner
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #8 on: Feb 01, 2011, 12:04:32 PM »
its a  new rebuilt carb for national carbarator  just had it on there a week
pie
81_yota
  • Male Posts: 299
  • Parcore !
Re: carb problems
« Reply #9 on: Feb 01, 2011, 03:36:11 PM »
i see posible bad regulator on mechanical fuel pump
warandall
  • Member since Jan '11
Re: carb problems
« Reply #10 on: Feb 01, 2011, 04:24:44 PM »
could check the vaccum lines again make sure they're fully seated and no cracks/wholes in the lines. also everytime mine starts idling ruff i change the fuel filter. its cheap and easy
81_yota
  • Male Posts: 299
  • Parcore !
Re: carb problems
« Reply #11 on: Feb 01, 2011, 04:37:54 PM »
might wanna drain tank clean it out and clean line to what year truck is it
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #12 on: Feb 01, 2011, 05:54:21 PM »
its a 86 with a sas and the tank is a 20 gal tank
pie
81_yota
  • Male Posts: 299
  • Parcore !
Re: carb problems
« Reply #13 on: Feb 01, 2011, 05:57:13 PM »
so did it run like that before you put new carb on ?
warandall
Re: carb problems
« Reply #14 on: Feb 01, 2011, 06:21:37 PM »
86 with a carb?
81_yota
  • Male Posts: 299
  • Parcore !
Re: carb problems
« Reply #15 on: Feb 01, 2011, 06:33:52 PM »
they made 22r up to 89 i think
warandall
Re: carb problems
« Reply #16 on: Feb 01, 2011, 06:37:14 PM »
weird, based on everything i have ever seen/read i thought after 85 everything was EFI. But i have defiantly been wrong before
81_yota
  • Male Posts: 299
  • Parcore !
Re: carb problems
« Reply #17 on: Feb 01, 2011, 06:49:37 PM »
efi more common after 85
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #18 on: Feb 02, 2011, 04:01:38 PM »
ran good with the first stock carb but like crab with a holley
350 first carb took a dump so i just got another stock carb
pie
81_yota
  • Male Posts: 299
  • Parcore !
Re: carb problems
« Reply #19 on: Feb 02, 2011, 04:09:57 PM »
did you make sure all vacs are hooked up correctly if so maybe possible the card u got is messed up
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #20 on: Feb 03, 2011, 07:30:26 AM »
i might since i have took all the smog off have it hooked up like a 84  canada model. if you look at it in the hanes book
pie
81_yota
  • Male Posts: 299
  • Parcore !
Re: carb problems
« Reply #21 on: Feb 03, 2011, 04:12:52 PM »
hmmmm did you block open ports and on dist make sure your advace is right and has both vacs hooked up
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #22 on: Feb 03, 2011, 04:38:01 PM »
pic
pie
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #23 on: Feb 03, 2011, 04:40:04 PM »
pic
pie
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #24 on: Feb 03, 2011, 04:44:11 PM »
ive put the thermastic vacuum switch were the egr vacuum switch was since i didnt need that switch anymore( the one with the 1 inlet and 2 outlet switch)
pie
RABIDYOTA
  • Turtle Points: -107
  • Male Posts: 336
  • Member since Mar '06
Re: carb problems
« Reply #25 on: Feb 03, 2011, 04:48:22 PM »
wheres the fuel filter?  my 86 surged only at idel  but at 23 mile to a gal. i lived with it, lets think ????    egr ?   2000 rpm ur out of idel circute,   there is a power valve in the carb under the fuel bowl, leaking? any other drivability issues ?
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #26 on: Feb 03, 2011, 04:57:52 PM »
the fuel filter is next to the tank. it surges at 2000 rpm when you rev it and hold it  at 2000 rpm .but at a pull when driving  it dont do it. it idles ruff and i have to turn the choke all the way off. were its open all the time because if i dont it well idle high all the time it want idle down
pie
RABIDYOTA
  • Male Posts: 336
Re: carb problems
« Reply #27 on: Feb 03, 2011, 05:01:40 PM »
float level?  vac. leak?
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: carb problems
« Reply #28 on: Feb 03, 2011, 05:10:04 PM »
float level looks good and i cant find a vacuum leak. im waiting on a new fuel pump to see if that might be the problem
pie
RABIDYOTA
  • Male Posts: 336
Re: carb problems
« Reply #29 on: Feb 03, 2011, 05:12:57 PM »
how are you adjusting the carb?  almost sounds like under  fueling    running lean if it idels better with choke on
Last post Jun 11, 2007, 09:30:37 AM
by fordh8r
Last post Jan 04, 2008, 08:59:00 AM
by 84socal
Last post Feb 05, 2008, 10:34:03 PM
by 70 Cam Guy
Last post Dec 14, 2008, 03:03:27 PM
by I.D.G.A.F
Last post Feb 20, 2011, 04:16:35 PM
by motormouth559
