Author Topic: 3rz to 3rz swap???? huh?got your attention yet??  (Read 4282 times)
tman
  • Member since Jan '11
« on: Jan 28, 2011, 12:42:02 PM »
thats right! 3rz to 3rz swap orig motor was a distributor, trying to swap to the coilpak motor. cant seem to find info on which engine harness # i need. its a plain jane no cruise, nothin special. ive dropped $200 on a coilpak harness from a 96  4x4 AUTO trans..... no reverse switch or 4X4 dash light plugs, no big deal, can deal with that. but my TPS is a 3 prong and the harness ive got for this proj. only has a plug for a two prong tps. engine will fire but wont run.....TPS has to be in circuit to run this badboy............HELP
01civ
  • Member since Jul '11
Anyone got info on this I want to do this also. I got a 3rz with 2 coil packs but want to put a 3rz with the coil on plugs. truck is a 2000 Tacoma 4x4.
tom w.
  • Male Posts: 760
  • Member since Jul '06
best thing i can do is suggest www.customtacos.com
they might be able to help.
01civ
Thanks. I'll check it out.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
Is there some benefit to swapping??
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
-Matt-
  • Turtle Points: -184
  • Male Posts: 1,010
  • Member since Jul '07
  • Full throttle Rollin steady
x2
ya sounds like a lot of work to not get any more power/torque. seems like the only advantage would be more modern.??
01civ
I needed a new motor so I bought one with the coil on plug ignition. So I figure it's newer might be better so why not try to use it. If anything I'm just gonna use my old ignition setup on the new motor.
-Matt-
  • Male Posts: 1,010
ya i understand getting a new motor, and that being what you got. i would just swap the original harness like you stated. you might run into more problems than would ever be worth it just for something a little more modern. but then again maybe its an easy plug and play without having to change maybe other harness/wires.
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
I have no idea if you plan on modifying the motor for more power or not, but I was told by LC Engineering that the older motor with the distributor was easier to make power on than the distributorless motors.
tryn2Crawl
  • Turtle Points: 11
  • Member since Feb '05
Got that right.
Last post Nov 07, 2019, 03:50:03 PM
by anders089
Last post Mar 04, 2020, 09:19:15 PM
by yoshaleng
Last post Apr 16, 2020, 09:51:51 PM
by 87SR5
Last post Jun 09, 2020, 11:48:43 AM
by mudmaster
Last post Sep 17, 2020, 12:53:33 PM
by 87SR5
