Located in Alaska 99702
PM, Email or call AJ at 372-1988
• Stainless steel swaybar disconnects. 86-95 stock height. Same ones as on
www.frontrangeoffroadfab.com/disconnects $75 shipped
• 1" bore Toy master cylinder w/ reserviour from 93 V6 p/u - $75 shipped
• Extreme duty ConFerr tranny/t-case skidplate. 79-95 Pickups and Runners - $50
• Red Poly swaybar bushings and snubbers/bumpstops - $?
• Stock Swaybar from a 93 pickup - $10 OBO
• Complete 1993 Toyota V6 transfer case - 2.57:1 low range, needs new front output seal, but works perfectly - $150 OBO This can now be used as the rear half of a dual tcase with a new MC10 adapter from Marlin Crawler! Pretty cool if you already have a 4cyl truck and want to run a dual case setup. And a less than half the cost of a 4cyl case!
http://board.marlincrawler.com/index.php?PHPSESSID=d079983c5d730fbd7049e6b86fd4731a&topic=5756.0. • allpro widebody shackles. $40
• Downey off road 110 sq inch aluminum air filter assy for 88-95 toy 3.0 V6 - $100
• 2ea Toyota V6 CV driveshafts. One is 65" long. $100ea
Subwoofer: 12" Kicker Solobaric L7. New in box. $200
Small computer subwoofer - $15
hedge trimmer, electric - $10
4x32 simmons scope. new - $30
• p/n M005-BB Gleason Torsen (now zexel torsen of Toyoda Ltd, Japan) Limited Slip differential. All gear LS, no clutches. Superior to the Tru-trac with a higher bias. This one is for a 30 spline dana 44, 3.92 and up carrier. New, never installed, in the original box. Perfect for a front or rear axle and undetectable on the street. Same exact device in the mil and civilian Hummers. $450 OBO
• p/n M008-BA Gleason Torsen limited slip. This one is for a 35 spline dana 60, 4.10 and down carrier. New, never installed, in the original box. Perfect for a front or rear axle and undetectable on the street. Same exact device in the mil and civilian Hummers. $500
• Spark Plug Wires 2 sets of Crane Cams 8.0mm FireWire. Universal 6cyl. Yellow. - $20/set SOLD
• Hood (perfect) and non-tilt steering column with keys from 89 GMC 3500 crew cab. make offers
• New in box. Lip Seal Installer Protector Kit for Turbo 400 tranny [TH 375/400/425(3L80)] by ATEC-TRANS-TOOL. $50 shipped
www.etoolcart.com/index.asp?PageAction=VIEWPROD&ProdID=743 www.transmissionpartsusa.com/TH400_Lip_Seal_Installer_Protector_Tool_Kit_p/300-0000t0124.htm--------------------------------------------------------------------------------------
• Shop Manuals
Chilton's Repair and Tune-Up Guide, Dodge Plymoth Trucks 1967-84 $10
Industrial Fluid Power Vol 1&2 $15ea $25 both
Factory Manual: Chevrolet 10-30 Series 1986 Light Duty Truck Wiring Diagrams $15
Caterpillar D3B Tractor Parts Manual Powered by 3204 Engine $10
Haynes Oldsmobile Cutlass 1974-1988 Repair Manual $5
Spicer Front and Rear Axle Parts, Ford 1979-1992, complete BOM and p/n info $10
(3ea) Chilton's Truck and Van Repair Manual 1971-1978 Gasoline and Diesel Engines $15 ea
Motor Light Truck & Van Repair Manual 1979-1985 $10
Chilton's Auto Repair Manual 1979, American Cars 1972-1979 $5
Chilton's 1969 Auto Repair Manual, American Cars from 1961-1969 Plus Volkswagon $25
NEW, UNOPENED Factory 1994 Ford Truck Series 600/900 Parts Catalog Vol 1&2 $50
Ford Factory Manuals 1994 F and B 600-700-800-900, Powertrain/Drivetrain $20, Body/Chassis $20, both for $35
Complete set of FACTORY SAAB 900 manuals excellent condition $75
