Author Topic: ARB Bearings  (Read 1130 times)
mathwizz90
  • Male Posts: 20
  • Member since Nov '08
ARB Bearings
« on: Jan 15, 2011, 07:00:28 PM »
Hoping maybe i can get an answer out of your guys, i cant seen to get a hold of the guys at Marlin Crawler. I just bought an Air locker for the rear end of my '85 pick up and started reading up on the install, theres something about maybe needing new carrier bearings for the locker, is this true? If so which ones do i need. Thanks.
crank
Re: ARB Bearings
« Reply #1 on: Jan 15, 2011, 07:23:21 PM »
u should start by getting some of that paint to mark ur gears to see how much contact there is in that teeth of that gears!
good luck
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Re: ARB Bearings
« Reply #2 on: Jan 15, 2011, 08:23:34 PM »
good luck
:headscratch:  :dunno:
If I am correct you need the 50mm ID bearings. I read that on ARB's website. I do not know what year those are.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: ARB Bearings
« Reply #3 on: Jan 15, 2011, 08:49:28 PM »
Same discussion on PBB. read all about what you need to do.
http://www.pirate4x4.com/forum/showthread.php?t=947375
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
    • oppiz.net
Re: ARB Bearings
« Reply #4 on: Jan 15, 2011, 09:57:59 PM »
If you are installing in a V6 housing you can use the factory bearings. If it is a 4cyl housing you need bearings that have a 50mm V6 inner and 4cyl outer. ARB only makes one locker for the 8" Toyota.
Koyo 32010JR
Timken also makes one under the same number and if you have a local bearing house they can prolly part match to what ever they sell.
Let me know i can get you a good price on a set of em.
http://oppiz.net/chat/index.php?topic=15.0
If you see it, its for sale.
Last post Jan 09, 2005, 09:35:35 PM
by reklund5
Last post Jan 21, 2005, 01:44:26 AM
by BLACKDOG
Last post Aug 16, 2005, 04:15:36 AM
by SLOYOTA808
Last post Dec 10, 2005, 08:12:51 AM
by 79coyotefrg
Last post Feb 05, 2007, 08:01:59 PM
by 89 toy
