Author Topic: Anyone swapped a 22R-E into a first gen?  (Read 1869 times)
HogCanyonHopper
  • Turtle Points: 7319
  • Male Posts: 1,224
  • Member since Jul '10
« on: Jan 08, 2011, 03:03:41 PM »
I have a wrecked '91 4Runner and am curious if anyone can give me any feedback on putting a 22R-E into a first gen. Hardest part would probably be the wiring and fuel delivery :dunno:
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
Re: Anyone swapped a 22R-E into a first gen?
« Reply #1 on: Jan 08, 2011, 04:43:02 PM »
It's the popular swap for the first gen
Also the w 56 tranny is the swap tranny that u want to use
The first gen transfer case is the only thing you are going to want to reuse
22 re. Re tank , re harness and computer and your old harness to splice into the re harness
Good luck
toyyota
  • Turtle Points: 5
  • Member since Apr '08
« Reply #2 on: Jan 08, 2011, 07:07:12 PM »
I did it, not bad at all for the most part. The engine bolts right in, I relocated trans mount cross member brackets on the frame. I used the small EFI fuel tank from a truck. The only challenge for me was the wiring, In order to pass CA. SMOG you need the check eng. light on the dash. I swapped in the 91 dash, or you can wire in the check eng light. You will enjoy the 22RE.  Bob.
HogCanyonHopper [OP]
  • Male Posts: 1,224
« Reply #3 on: Jan 08, 2011, 07:31:19 PM »
Thanks for the feedback. The wreck has been sitting at my folks place since June '07. I am going to trailer it up to my place and go from there. FUTURE project. I will run the 20R for a while. 3RZ would be sweet but, have that wreck with everything there.
Thanks again guys :thumbs:
cen-cal crawler
  • Turtle Points: 10
  • Male Posts: 690
  • Member since Mar '09
« Reply #4 on: Jan 09, 2011, 01:07:02 PM »
hardest part was wiring up the cluster as i switched to an sr5 cluster. only problems i had were the gas tank was too big and the tranny crossmember. its a very nice swap to have done.
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________|
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
« Reply #5 on: Jan 09, 2011, 01:47:00 PM »
If you have a 20r I would lean towards just rebuilding the 20r.  I have run 22re, 22r and 20r and I have been the happiest overall with the 20r.  My carb runs very well at all angles, which would be the only reason I would go to EFI.  My buddy has a 22re and I can pull hills on the highway better than he can with the 20r even though he has good gearing and I don't.
I do have a '94 I am swaping the 3rz into...
– Steve McQueen
stevesyota
  • Turtle Points: -5
  • Male Posts: 67
  • Member since Nov '08
« Reply #6 on: Jan 26, 2011, 07:45:24 PM »
I just found a deal on a 22RE intake, throttle body, wiring harness, and computer. I should pick it up this weekend and clean it up and put it in very soon. I have an 84 with a 22R. :thumbs:
84 Toyota Pickup SR5
Last post Feb 19, 2008, 07:49:13 PM
by 84pickup
Last post Jul 05, 2009, 10:42:00 PM
by sirhc0306
Last post Oct 18, 2009, 03:17:03 PM
by wslytoy
Last post Jul 20, 2011, 11:47:20 AM
by Sparkplug
Last post Apr 06, 2023, 07:44:09 AM
by 4runner17
