Author Topic: T-case spine mount  (Read 2423 times)
poor boy pulling
  • Turtle Points: -5
  • Member since Aug '06
T-case spine mount
« on: Dec 22, 2010, 09:24:22 PM »
So was just wondering the buggy project I picked up has a tcase spine on the rear case but no other tranny or tcase mount, question is should I add another mount to the front case or? I have seen a few rigs running only the spine and they wheel pretty hard, just wanting to make sure its strong enough. Any advise would be great thanks
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: T-case spine mount
« Reply #1 on: Dec 22, 2010, 09:54:00 PM »
if u are saying that the t-case mount is bolted to the back of the case, then yep its fine, thats how alot of guys run them.
poor boy pulling [OP]
  • Turtle Points: -5
« Reply #2 on: Dec 22, 2010, 10:02:25 PM »
ya it has the mount that bolts on to the bolts of the back of the tail housing. i just thought it was alittle long between the engine and the rear mount but i have seen more than one rig run it that way and never had a problem.....
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
« Reply #3 on: Dec 23, 2010, 09:29:35 AM »
ya it fine, lots of people run them.
one thing to check would be your motor mounts. these t-case mounts are a lot harder on the stock mounts so you may want to switch to solid motor mounts (if it dosent already have them.)
  • Turtle Points: -5
« Reply #4 on: Dec 23, 2010, 11:15:39 AM »
cool deal one less thing i have to build in it.... ill inspect those when i pull the engine out of it. thanks for the info guys!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #5 on: Dec 23, 2010, 07:20:09 PM »
Actually, it is easier on the motor mounts. With the FROR, type t-case the engine/tranny/t-case is mounted four points, whereas with the stock set-up it is three points. The four-point mounting stabilizes the combo better then the three points. That was one of the first things we use to change on high torque drag car set-ups if it was only three points, three-point set-up would rip the MM’s on launch.
  • Turtle Points: -5
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
« Reply #7 on: Dec 24, 2010, 03:49:05 PM »
ya oops is right. i must have been thinking about the solid stock style.  :smack:
Last post May 21, 2004, 11:04:41 PM
by WHITE_TRASH
Last post Jul 03, 2005, 06:26:32 PM
by ensmyers
Last post Sep 21, 2009, 04:07:03 PM
by boggerunner
Last post Jan 04, 2011, 10:46:01 AM
by vaj70cruiser
Last post Jan 04, 2011, 10:47:34 AM
by vaj70cruiser
