Author Topic: 1981 toyota 22r vac.  (Read 1744 times)
m.dilbeck
  • Turtle Points: 2
  • Member since Dec '10
« on: Dec 11, 2010, 10:35:05 PM »
i pulled the stock 81 motor out it was a ca truck so it had a ton of vac i pulled a motor out of an other truck but it does not have a smog pump and it ony has a little bit vac.. i want to get rid of all the crap under the hood i dont need... i am not going to smog this truck it is getting a green sticker. i want ot run the stock carb so please help show some pics let me know i need to get this finished asap.. thanks
T.Rex
  • Male Posts: 164
  • Member since Mar '10
Re: 1981 toyota 22r vac.
« Reply #1 on: Dec 20, 2010, 08:19:02 AM »
Pirate has a good section on what vacs are needed just search
Rocksnail
  • Turtle Points: 3
  • Male Posts: 595
  • Member since Jun '07
« Reply #2 on: Dec 20, 2010, 12:51:11 PM »
All i have on my 82 is the vac lines for the distributor, brake booster. of course i do run a webber and a DUI distributor. but im pretty sure that is all you will need. There might be one for the carb i dont recall.
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #3 on: Dec 20, 2010, 09:30:48 PM »
Same here, pos weber with 1 for vacuum advance and 1 for brake booster, nothing else.  I'll be converting to a 22r carb soon and will be figuring out which vacuum lines can go and which absolutely have to stay.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #4 on: Dec 20, 2010, 09:42:06 PM »
all u need hooked up is brake booster, and dizzy adavnce, only 1 need run to dizzy also, 1 can be blocked
Last post Mar 25, 2005, 11:24:05 AM
by Raven
Last post Dec 21, 2005, 07:50:34 PM
by rangerkid
Last post Dec 11, 2007, 04:28:27 PM
by fatt_matt
Last post Nov 14, 2008, 10:25:44 AM
by 4x4yota
Last post Oct 30, 2021, 12:29:14 PM
by H8PVMNT
