Author Topic: duel cases  (Read 2776 times)
raptorman57
  • Member since Oct '02
  • Grab a bear and gas it!!!!!!!!
    • click here to see my toys
duel cases
« on: Dec 30, 2002, 01:15:21 AM »
:help:
I have a 87 Toyota with an aluminum 5 speed and want to run duel x cases. A freind of mine has the x case for a cast 4 speed and a x case for an aluminum 5 speed. Which one do I need to buy? He will sell me either one I just need to know which one I need or which one is better. I've heard there's only one you can use but not sure which one that is and how to tell them apart. One thing I heard is I need the top shift x case. Is the top shift case from a cast 4 speed or aluminum 5 speed? Please help and thanks in advance.
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
Did you know Jesus drove a Chevy? Sure did, Do you know how I know?
Cause he had to walk everywhere.
rEdnECkwHeE1eR
  • Turtle Points: -68
  • Male Posts: 1,430
  • Member since Jun '02
  • Still tipin'
Re: duel cases
« Reply #1 on: Dec 31, 2002, 08:39:08 AM »
Is the 5 speed case from a fuel injected truck or carb? If EFI use it aslong as its 88 or older. If carbed use the one of of the 4speed:up:
Liquor up front
Poker in the rear
raptorman57 [OP]
Re: duel cases
« Reply #2 on: Jan 04, 2003, 12:11:59 AM »
Well I have an 87 carbed truck. I don't know how to tell them apart. Can someone post pics of the 2 different cases so I can see the difference between the two?
Thanks!
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
  • MC20/21 Toybox #002 2.28 = 154:1
    • MTA
Re: duel cases
« Reply #3 on: Jan 06, 2003, 02:25:07 AM »
It is either a gear driven or chain driven case. (from the website)
Gear
Chain
There is a chain driven case that drives on the same side as the gear driven case. The shifter will come out the top of the tcase or the tail housing of the transmission.
The other thing you need to know is if it is 23 or 21 spline. That should be easy if it is apart already ;)
Paul_Elbisser
  • Turtle Points: 43
  • Male Posts: 329
  • Member since Aug '02
  • Supra Powered
    • KraZyfly
Re: duel cases
« Reply #4 on: Jan 06, 2003, 06:02:17 AM »
The chain drive cases came only on auto trans in 87. What you will nee to find is any gear driven case after 81. the best to get would be a top shifting case that came from an EFI truck.  Your truck may have a forward shift case in it now, or a top shifter like in the top pic on Cruzilla's post.
If you can only find a forward shifting case Marlin does sell the conversion kit. It could also be a good time to put in a short throw shifter.
If your stock case is forward shift you can leave it in as the crawl box and put the top shift in the rear. If you have a top shift case, then you can build the new case as the crawl box and put it between.
Or I could be wrong and the mediction is talking.
Paul Elbisser
PastTLCA Eastern Rep,
Pres. Rice on the Rocks
One of Those Guys
cruzila
  • Go go cruzila!
  • Hawk
  • Turtle Points: 41
  • Male Posts: 3,848
    • MTA
Re: duel cases
« Reply #5 on: Jan 06, 2003, 08:10:07 AM »
How was the flight?
How is the arm?
Paul_Elbisser
  • Turtle Points: 43
  • Male Posts: 329
  • Supra Powered
    • KraZyfly
Re: duel cases
« Reply #6 on: Jan 06, 2003, 10:37:09 AM »
flights went well. got to board with first class.  slept through most of it.
had to deal with my heath plan today, they won't tell me anything till tomorrow about my disability benifits.
Paul Elbisser
One of Those Guys
Last post Jan 20, 2008, 03:59:59 PM
by mendo
Last post Jul 14, 2008, 05:42:06 PM
by Thumper
Last post Oct 29, 2008, 09:14:57 PM
by boggerunner
Last post Dec 05, 2008, 08:34:22 AM
by DTB
Last post Sep 26, 2013, 03:12:31 PM
by TEXCRAWLER
