Well i am 100% certain its not your LIFTERS But what it could be is maybe your t-chain is loose and hitting the cover and maybe you jumped a tooth on timeing
how far should i advance the timing? all the way?
If the chain is worn enough to skip a tooth causing your problem, it wont be too long before it breaks. Which if it breaks, you are looking at a lot more issues than just the timing.Have you checked/inspected the timing chain yet, or checked/adjusted the valves, inspected the spark plugs, cap & rotor, and plug wire, etcs.? You need to make sure everything else in in proper working order before adjusting the timing. If you don't know how to do this type of service, the FSM posted above will all but hold your hand through the process.
which kit should i get from auto zone if im just gonna replace the whole thing?http://www.autozone.com/autozone/parts/1989-Toyota-Pickup-4WD-4-cyl/Timing-Set/_/N-iub25Z8znax
Started by Opias Toyota Pickup/4Runner Tech 1979-95
Started by BLACKDOG Tow Rig and Trailers
Started by 91xcab Toyota Pickup/4Runner Tech 1979-95
Started by Toyospearo Toyota Pickup/4Runner Tech 1979-95
Started by waldo2315 New Member Check-In!
