Author Topic: Hydro Assist on a DD  (Read 2849 times)
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
« on: Nov 05, 2010, 01:50:15 PM »
My question is how can I put together a reliable hydro assist for a light DD. I don't drive it too much (~500miles/month) but I do occasionally take long drives for travel and I do drive to and from trails.
Plus, where can I get a good rebuild kit for a 96/98 IFS box?
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
  • Member since Nov '08
    • oppiz.net
Re: Hydro Assist on a DD
« Reply #1 on: Nov 05, 2010, 04:15:24 PM »
If you see it, its for sale.
HDcruiser
  • Turtle Points: 10
  • Male Posts: 580
  • Member since Dec '06
« Reply #2 on: Nov 05, 2010, 04:32:53 PM »
Next on my wish list  :gap:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #3 on: Nov 05, 2010, 04:44:23 PM »
$180 for just the ram and hardware.
http://www.pscmotorsports.com/Cylinders/1.5x6-Assist-Cylinder.html
Now their shafts are only .625". Most others are .75". Is there a concern with this? I know PSC has an excellent reputation and I have no problems with running their stuff.
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Member since Aug '09
  • Not all who wander...are lost
« Reply #4 on: Nov 05, 2010, 05:04:06 PM »
I run a TG pump a six inch stroke surplus center ram shaft is .75". And I have a big oil cooler and big resevoir and filter. I dd mine everyday. To and from trails hundred mile trips no problems.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #5 on: Nov 05, 2010, 05:24:06 PM »
Just keep in mind a single ended ram will have more power on one side of the ram (extending).  So a smaller dia. piston will help compensate (but is weaker).  A double ended ram would solve the problem.  Bigger bores require more flow, so higher flow pumps are required as well as coolers, and bigger reservoirs.  All said, I run a 2" bore, 1" piston 7" stroke, GM pump, Toy box, ATF and have no problems.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #6 on: Nov 05, 2010, 06:48:04 PM »
That makes sense, more power on the extending stroke. I'm running 37s and I'm looking for something to take the strain off my steering box. A double ram would be cool but overkill. I will put/make a larger reservoir and large cooler in (I have a trans cooler somewhere). The line will probably be made by an tractor store in town.
Should I look into using hiems instead of tie rod ends?
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
« Reply #7 on: Nov 05, 2010, 07:08:26 PM »
I use heims, it depends on preference and travel, use what works.  If you use heims, in single shear, make sure to use some kind of safety washer, in case of failure.
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #8 on: Nov 05, 2010, 07:49:33 PM »
IFS box rebuild kits? the OP and I are wondering
Last post Mar 05, 2006, 04:37:42 AM
by POWERSTROKEN
Last post Jul 24, 2010, 10:14:40 AM
by megolfer
Last post Sep 15, 2007, 09:25:38 AM
by subliminaltrips
Last post Oct 13, 2010, 11:53:27 AM
by -Jake-
Last post Apr 20, 2011, 05:17:32 PM
by yoshaleng
