Author Topic: e-brake line  (Read 1828 times)
SpencerS
  • Member since Oct '10
e-brake line
« on: Oct 29, 2010, 07:31:57 PM »
Hey guys. I am just wondering how to tighten the e brake line. It doesnt work when it is fully pulled out. The line has a ton of slop when not engaged and its a little sloppy when it is engage. How would i go about fixing this and/or tightening the line?
Thanks guys!
CSR73
  • Turtle Points: 7
  • Male Posts: 176
  • Member since Aug '10
Re: e-brake line
« Reply #1 on: Oct 29, 2010, 07:43:16 PM »
The cable may be broken.  Pull the aluminum housing and roller (under hood, on firewall) and check.  The barrrel shaped cable end on both of my 1st Gen cabs were broken.  I found a new cable at Autozone for around $30.  There is also an adjustment under there... in front of the fuel tank, if the cable is ok.  Also may want to make sure the rear brakes are adjusted properly, if everything else looks legit.
'85 4runner in the works
SpencerS [OP]
Re: e-brake line
« Reply #2 on: Oct 29, 2010, 07:54:17 PM »
Could it still be broken if it engages slightly? Ill check under the hood tommorow morn.
CSR73
  • Turtle Points: 7
  • Male Posts: 176
Re: e-brake line
« Reply #3 on: Oct 29, 2010, 08:46:04 PM »
I'd check under hood first.  Two 12mm nuts to loosen the cable cap/guide and check that end of the cable.  If strands are frayed/broken but still mostly intact, adjustment at the frame might buy a little time.  Make sure the rear shoes are adjusted properly before you mess with the e-brake cable adjustment under the cab.
I know what the problem is with my e-brake.... just haven't repaired it yet.  I'm carrying around a piece of broken cinder block to kick under a tire!
SpencerS [OP]
Re: e-brake line
« Reply #4 on: Oct 29, 2010, 10:02:14 PM »
Alright ill check the shoes anything specific i should look for?
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: e-brake line
« Reply #5 on: Oct 29, 2010, 10:49:16 PM »
Make sure they are adjusted with a slight drag when turned.
Last post Dec 23, 2007, 11:47:07 AM
by KYOTA
Last post Jan 22, 2011, 12:51:22 PM
by DaveZ
Last post Dec 05, 2011, 08:03:54 PM
by Dirt Mover
Last post Feb 17, 2012, 09:23:32 PM
by yotaneck13
Last post Jul 13, 2013, 12:27:01 PM
by zembalayan
