Author Topic: ARB locker issue  (Read 1977 times)
JOE 88
  • Member since Jan '09
ARB locker issue
« on: Oct 27, 2010, 07:26:45 PM »
So iv got ARB lockers front and rear on my 88 sas pickup. my rear works awsome. but my front is tempermental. half time it locks and the other half it leaks air out of my diff vent. im thinking that my air connection at the locker is the cause. but im trying to see if anyone else has had this problem before i pull my frony end apart.
88 pickup marlin SAS 5in spring ARB's F/R  Dual cases 35' BFG KM2 5.29
rockin86runner
  • Turtle Points: -18
  • Male Posts: 871
  • Member since Nov '07
Re: ARB locker issue
« Reply #1 on: Oct 27, 2010, 07:39:29 PM »
i had that same problem for a few weeks then it just stay engaged now dont have time to fix it let us know if you find something else out
85 toy runner tons 4link front and rear ORIs 42 pitbulls
86 runner some other things  pained orange STOLEN REWARD IF FOUND
70 cj-5 renegade1 buick 231 v-6 t-18 dana20 dana 30,44 32in BFG at
 :usa: USN SEABEE EO2 SCW .....We Build.We Fight.We Defend....Hoo-Rah  GOD BLESS OUR TROOPS :usa:
JOE 88 [OP]
« Reply #2 on: Oct 27, 2010, 07:46:40 PM »
ya its weird. once i get it to engage it work awsome. but its just a pregnant dog to get locked sometimes. i will keep you updated  to what i find. hopfuly i can fix it
66cobra
  • Turtle Points: 34
  • Member since Mar '08
« Reply #3 on: Oct 28, 2010, 05:32:24 AM »
i have the same problem when it gets cold out. it goes away once the gear oil warms up possibly a lower viscosity gear oil or locking the hubs up a while before needed use would help.
it's not me, it's you
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
« Reply #4 on: Oct 28, 2010, 10:06:07 AM »
66 cobra is right im pritty sure, had a simmler problem with viscosity, and make sure no kinks, check from pump to axil!!
hope this helps good luck !!!!
JOE 88 [OP]
« Reply #5 on: Oct 28, 2010, 06:23:50 PM »
i never thought that gear oil could be a factor. i will def look into it. thanks
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
« Reply #6 on: Oct 28, 2010, 07:11:33 PM »
If its blowing air out the breather i bet one of the o rings is bad in the collar.
91 Toyota High pinions f&r.
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #7 on: Oct 29, 2010, 02:05:26 AM »
If it is a new set-up(installed within the last 3-4yrs) the compression coupler at the housing is a bit of a PITA, too tight and you crush the rubber o-ring, too loose and it doesn't seal up correctly.  Might remove the coupler at the diff and see what the o-ring looks.  If the o-ring is bad, call ARBUSA and talk to the tech department, they will likely send you a new fitting at no charge.
« Last Edit: Oct 30, 2010, 02:31:43 AM by Snowtoy »
rolldog
« Reply #8 on: Oct 29, 2010, 08:06:53 PM »
yeap.. i have the same problem like 66cobra too.. the other day i was up camping on the dusy trial, next morning i try to lock my rear arb and it wouldn't lock right compressor keep pumping and then after a awhile driving when the gear oil warm up it look great......... is it normal?
Last post Jan 25, 2005, 03:29:51 PM
by FATB0Y
Last post Aug 27, 2007, 03:14:21 AM
by crawler925
Last post Jan 23, 2008, 07:40:32 PM
by 86bobbedtoy
Last post Apr 26, 2008, 02:54:07 PM
by Hammerhead
Last post Jan 25, 2024, 12:56:41 PM
by Snowtoy
