Author Topic: bouncing speedo  (Read 3826 times)
TacoStewie
  • Turtle Points: 4
  • Male Posts: 816
  • Member since May '06
bouncing speedo
« on: Oct 04, 2010, 11:17:09 PM »
What would cause a speedo to bounce?  i have a 95 4runner with a later gear drive t-case and the speedo will bounce 5 to 10 mph. it is also reading way faster that i am going. are there diffrent speedo gears for diffrent years?
thanks for the help
4THEWKN
GreenYoterKrawler
  • Turtle Points: -4
  • Male Posts: 225
  • Member since Sep '10
Re: bouncing speedo
« Reply #1 on: Oct 05, 2010, 12:16:09 AM »
Well how many miles are on ur rig? I just put a 4.7 into my t-case and the case has roughly 230k, when i pulled the speedo sender out i noticed there were almost no spline left only slivers on a few of them. so u may need a new sender also the plastic splines were warped so im sure this is why my speedocable broke, just my  :twocents: tho, GL
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: bouncing speedo
« Reply #2 on: Oct 05, 2010, 02:32:03 AM »
Bouncing speedo, I had that happen and soon after the cable broke. It was binding up from a burr in the housing.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
Re: bouncing speedo
« Reply #3 on: Oct 05, 2010, 11:37:04 AM »
The bouncing speedo is from the speedo cable binding up.  I've had some luck fixing it on a few trucks by removing it at both ends and having a friend turn the trans end with it in a drill, while I spray some penetrating lube down the dash side of it.
Yes, there are differend gear sizes for the speedometer gears.  I think it all depended on what size R&P the rig came with.  I believe the speedo gears have the number of teath on the edge of them.  See if your local Toyota dealer can hook you up with the right one.
If your 4runner came with a 4:30 R&P, you might want to change the speedo gear to an older truck who's lowest R&P ratio is a 4:10.
TacoStewie [OP]
  • Turtle Points: 4
  • Male Posts: 816
Re: bouncing speedo
« Reply #4 on: Oct 05, 2010, 05:51:07 PM »
sweet thank you
4THEWKN
billabongo
  • Member since Feb '11
Re: bouncing speedo
« Reply #5 on: Feb 26, 2011, 05:40:14 PM »
Correct me if I am wrong, but I am pretty sure his 95 year 4runner has an electronic
Speedometer. There is no cable, just a speed sensor on the right
side of the transfer case near the output shaft.
This has a 4 wire connector, 2 go to the computer, 2 to the speedo.
I have had good luck removing the sensor and gear unit, cleaning the sensor portion
With electrical cleaner and replacing all the o-rings on the unit and cleaning
The contacts on the plug.
The sensor itself rarley will fail as it has no moving parts (sensor itself)
Normally they fail if the rubber membrane that seals it leaks trans fluid inside.
Often when u remove it you will find that the o-rings have been leaking and "can" cause
issues with the magnetic hall sensor accurately sensing the revolutions and can result in issues.
Other issues could be:
-the gear is damaged, causing jumping  as teeth could be missng.
-Loose wire connection between speedo and sensor
-The stepping motor in the speedometer has issues or is sticking
« Last Edit: Feb 26, 2011, 07:05:34 PM by billabongo »
TacoStewie [OP]
  • Turtle Points: 4
  • Male Posts: 816
Re: bouncing speedo
« Reply #6 on: Feb 27, 2011, 06:11:33 PM »
nope it has a cable from the spedo all the way to the t-case.
4THEWKN
HULK
  • Turtle Points: 306
  • Male Posts: 164
  • Member since Dec '10
Re: bouncing speedo
« Reply #7 on: Feb 28, 2011, 10:58:32 PM »
Definitely the cable.
86toyota
  • Turtle Points: 2
  • Male Posts: 353
  • Member since Nov '07
    • Montana 4x4 Association
Re: bouncing speedo
« Reply #8 on: Mar 01, 2011, 12:29:21 PM »
maybe that is why mine quit working. It was bouncing for a while. quit doing that then worked fine. then the other day it quit working all together. havent had time to mess around with it yet tho
T86OTA
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
Re: bouncing speedo
« Reply #9 on: Mar 01, 2011, 12:45:42 PM »
mine started bouncing around for a day.  checked it out, and the drive flange on the back of the tcase where the drive line bolts up had worked itself loose.  tightened it back down, hammered over the lock tab again, and its been good ever since. not sure why this had any effect on the speedo, but it did somehow.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
lownlinked85
  • Male Posts: 408
  • Member since Mar '08
  • Yeah Baby!!!
Re: bouncing speedo
« Reply #10 on: Mar 01, 2011, 10:45:55 PM »
had the same exact thing happen to me the flange just came loose crazy
Low locked and ready to rock
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
Re: bouncing speedo
« Reply #11 on: Mar 01, 2011, 11:14:52 PM »
Mine bounces when the bass is turned up... Haha  :laugh:
GreenYoterKrawler
  • Turtle Points: -4
  • Male Posts: 225
Re: bouncing speedo
« Reply #12 on: Mar 02, 2011, 05:11:53 AM »
 :rofl2: nice one
 who needs a speedo thats gonna be 10+ mph off anywayz, i just use my tach and this
 http://www.offroaders.com/info/tech-corner/reading/calculators.htm#FindMPH
All you really need to know is RPM's for 25, 40, and most specially 65 mph. and ur set  :biggthumpup:
pistolbob
  • Turtle Points: -1
  • Male Posts: 17
  • Member since Jul '10
Re: bouncing speedo
« Reply #13 on: Mar 07, 2011, 05:00:16 PM »
Every time I see the title of this thread it makes me laugh then vomit a little because I think of the speedos at the beach.
  :reg:
  • Momentum Man
  • Lego Enforcement
Re: bouncing speedo
« Reply #14 on: Mar 08, 2011, 03:51:58 AM »
  :reg:
Why you lookin?  :haha:
TacoStewie [OP]
  • Turtle Points: 4
  • Male Posts: 816
Re: bouncing speedo
« Reply #15 on: Mar 08, 2011, 08:27:53 AM »
4THEWKN
sheepdawg
  • Member since Mar '11
Re: bouncing speedo
« Reply #16 on: Mar 10, 2011, 07:18:00 PM »
hmm... my speedo bounces sometimes... i got a 89 toyota that had a 3.0 5speed and now its got the 3.4.. its always done it though... sometimes it will start bouncing way faster than normal and then go all the way to 110mph... shut the truck off and crank it back up and that fixes it sometimes... and sometimes it just fixes itself.. been doin it for about 3 years now... i havent fooled with it but now im thinkin about it
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
Re: bouncing speedo
« Reply #17 on: Mar 14, 2011, 05:53:38 AM »
Fool with it now before the speedo cable breaks - They can be a pain to replace.
Last post Jul 17, 2008, 06:45:12 AM
by beyondlogic
Last post Jan 19, 2009, 09:41:48 AM
by Rocksurfer
speedo
Last post Oct 12, 2009, 12:31:25 PM
by kneedownnate
Last post Apr 18, 2011, 09:50:45 AM
by OOPS
Last post Dec 12, 2016, 06:38:57 AM
by redneckcustoms13
