SPOOL?
Started by 4DEES, December 26, 2004, 08:19:01 PM
FATB0Y
Quote from: KYOTA on January 06, 2005, 03:29:13 PM
Found some old threads on PBB, basically a toss up, sounds like the spools that did fail were the thinner flange ones. BUT I did see a post where Gearman said any carrier will flex. So a welded 3rd is capable of deflecting and shearing teeth too, granted probably not as easy beings the part of the carrier that houses the side and spider gears on an open 3rd is closer to the ring gear mounting flange than is with the center of a spool. I'm not worried about it, and if I ever do nuke my spool I'll be sure to post the carnage pics. Now watch the next time I go out I'll break it.
:yesnod: Yep you put your mouth on it.... ya might as well start lookin in to gettin a new one :yupyup:
KYOTA
RE:Todd
Yes, I've had two rear ring and pinions go out due to spool deflection.  One in the Old Bus, one in this one.  This one is Formula Toy #006, Ultimate Crawler, 37's, 4.10 axle gears.
Quote from: KYOTA on January 05, 2005, 10:49:18 PM
Have you seen this 'deflection' in our application or are you talking about 5000 hp top fuelers?
TinBenders
Carnage Champs 2002/2003
Formula Toy #006
Thanks to:  Deaver Springs, High Angle Driveline, Rock Buggy Supply, Bilstein Shocks, Toyota SuperAxles (Longfield), Marlin Crawler, Coast Motor Supply, PRP Seats, Rockstomper.com
KYOTA
I guess it all boils down to the stiuation, everything will break. Todd what do you run in place of a spool now?
cgbemis
Quote from: slowroller on January 06, 2005, 07:37:19 PM
If you weld the carrier you run the chance of it exploding under a load while 4 wheeling hard!
If you have a diff welded by a competent welder, it shouldn't be a serious issue.
Skinny_Pedal
what is deflection?
Im an OG
derek
KYOTA
Quote from: 86runner on January 07, 2005, 11:55:39 AM
what is deflection?
Say you have a tire wedged, your trying to get it and your not making forward progress, the force that is being applied to the gears has to go somewhere so the pinion in essence pushes (deflects) the ring gear away, the contact pattern of the gears is now too far up on the ring gear teeth and causes failure.
RE:Todd
Welded until I can pony up some cash for a rear ARB.
Quote from: KYOTA on January 07, 2005, 08:39:49 AM
TinBenders
Formula Toy #006
moutaintoys
that &4x4 labs steering & you can turn like me
Lets go break somethin "GO NAVY"
4DEES
well damn! now I might just weld it. thanks for all your guys' 411.
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
