Author Topic: newbe  (Read 1397 times)
shallcallhimtim
  • Member since Aug '10
newbe
« on: Aug 31, 2010, 06:07:13 PM »
hey guys im a new fj80 land cruiser driver and i have som e questions. I resently rebuilt buthe of my knuckles and they have now started to leek. I kno thats not normal but i dont kno what the deal is? I guess i need to replaced the seals again? Also i but some longs in it and they stick out ferther than the old ones is that normal?
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
Re: newbe
« Reply #1 on: Aug 31, 2010, 06:49:30 PM »
replace the seals again and welcome
kombatics
  • Turtle Points: -33
  • Member since Sep '10
Re: newbe
« Reply #2 on: Sep 01, 2010, 02:12:21 PM »
How much longer are they?
kombatics
Re: newbe
« Reply #3 on: Sep 01, 2010, 02:12:43 PM »
and that sucks about the seals again.
germ
  • Turtle Points: 349
  • Male Posts: 733
  • Member since Dec '04
  • Work sucks, I'm goin' wheelin
Re: newbe
« Reply #4 on: Sep 03, 2010, 04:31:43 PM »
Check the diff breathers. If they're not working, it can build up too much pressure in the diff as they heat up, and blow the 90w past the seals. If they're new, and you didn't damage them on the install, they should survive the gear oil blow by. Might want to check the knuckles and make sure you don't have wheel bearing grease soup (mixed with 90w). Could cause an early death in there.
While your at it, if you plan on wheeling it where there is a chance of water crossing, save yourself alot of headaches and put extended breathers on it. The redneck way is to pop the spring loaded cap off, get some fuel line and clamp it on, then run it up into the engine bay. There are some metric adaptors you can buy, which make this more professional, but either way works well. Some like to put a fuel filter on the end of the hose to keep those pesky mud-wasps from building a nest in there (ask me how I know). Not sure on the fj80, but on the 4Runner, I was able to run the hose on the rear housing up into the tail-light assembly, keeping it out of harms way.
Erik
Last post Aug 23, 2006, 06:03:31 PM
by Duffil
Last post Sep 16, 2007, 08:47:02 PM
by Tallchevy
Last post Jan 25, 2008, 10:55:21 AM
by Kimber
Last post Apr 14, 2012, 03:13:44 AM
by 4 runner4play
Last post May 04, 2016, 10:05:20 PM
by Rocksurfer
