Author Topic: Driver or passenger side drop????  (Read 5868 times)
4wheelingdude
  • Turtle Points: -9
  • Member since Sep '07
« on: Aug 21, 2010, 06:07:43 PM »
Which side is better on the Tacoma?  I bought a taco with a HP dana 44 in it, but I have a 85 Toyota front diff with HP E locker I am going to put in the taco.  Just seeing what everyone thinks.
The transfer case is broken, so that is why am asking.
Yes I know things have to be modified to change the drop.
-11 Nissan Titan Crew cab Pro-4x (factory rear locker) - New work truck/tow Rig
CRAWLERS:
FOR SALE :99 TACO EXTRA CAB WITH DUAL 4 CYL LEFTY TRANSFER CASES with Marlin 30-Spline Chromoly Front Output Shaft and rear  30-Spline Chromoly Output Shaft ON 35'S - $8,500 OBO  or  $5,500 OBO without the dual lefty, front drive shaft and cross member-Make offer as truck MUST go ASAP
02 taco double cab with a tube bed on 1 tons and linked!
Reynolds
  • Turtle Points: -20
  • Male Posts: 491
  • Member since May '04
Re: Driver or passenger side drop????
« Reply #1 on: Aug 21, 2010, 08:58:19 PM »
If you switch to passenger side drop, you'll have to re-route your exhaust to clear the driveshaft. You'll get more t-case gear options with a passenger drop. Personally, I think the HP44 is the perfect axle for a Taco. The Toyota axle is too skinny unless you go with a Diamond housing.
-Brian
4wheelingdude [OP]
  • Turtle Points: -9
« Reply #2 on: Aug 21, 2010, 09:21:37 PM »
Well  I agree, but I bought the E-locker and the housing for my 4 runner(now selling), but found a sweet deal on a Tacoma with dual cases already with a broken transfer case.  I'll be saving the HP dana 44 for my double cab build, if I use the Toyota front.  thanks for your help.
CRAWLERS:
yotatough
  • Turtle Points: 16
  • Member since Oct '06
« Reply #3 on: Aug 22, 2010, 07:27:42 PM »
you will need to run large spacers up front to match the rear, but other than a little modding, I like pass drop, thats what I run in my 97 runner.
4wheelingdude [OP]
  • Turtle Points: -9
« Reply #4 on: Aug 23, 2010, 10:06:50 PM »
I already got the 3" spacers for the front as I was going to run a taco rear in my 4 runner
CRAWLERS:
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
« Reply #5 on: Aug 24, 2010, 08:07:16 PM »
If you do driver side drop you can go D60 cheaper.. if you decide to go that route.... Ford 60's are alot cheaper than a chevy 60.
Last post Sep 01, 2004, 11:31:16 AM
by dirtbag
Last post Feb 06, 2006, 11:50:18 PM
by sandboxtoy
Last post Jan 21, 2009, 12:06:56 PM
by jeremiah
Last post Jun 18, 2010, 11:53:53 PM
by gtoyonrocks
Last post Feb 21, 2015, 07:45:06 PM
by Willard
