Author Topic: 1984 toyota 4x4 22r  (Read 4582 times)
superkaliguy
  • Member since Oct '09
1984 toyota 4x4 22r
« on: Aug 19, 2010, 10:00:41 PM »
here is my problem:
 The engine turns on and then it idols and cuts out. But if i try it agian, i turn it on, put it in gear and try to drive off, but it cuts off again. It hesitated  like bogging and dies out, i'm not sure what the problem is?
thank you any help is appreciated.. thank you
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
  • Member since Mar '10
Re: 1984 toyota 4x4 22r
« Reply #1 on: Aug 20, 2010, 03:46:18 PM »
The only good thing about this post is the hot girl on her knees.  You need to be a little more descriptive.
83 pickup, 4.88s, chevys in rear, RUF, Dual Transfers, flat belly, 3RZ swap, disc brake x4, rollin on 36" irocs
IF YOU SEE A 20' PAC WEST/CARSON FLAT BED TRAILER FOR SALE CHECK OUT THE STOLEN SECTION.  IT MIGHT BE MINE!!!!
superkaliguy [OP]
« Reply #2 on: Aug 20, 2010, 04:02:50 PM »
sorry about that.
will getting on too the problem, when i start the car it idls and sounds ok, but for just a short time like 2-5 seconds, then it feels like the car is not getting any gas and it dies out..u would figure if you give it a little more gas it would reve up, but it just studers  and ends up dieing, could it be the distributor
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
« Reply #3 on: Aug 20, 2010, 09:37:53 PM »
the timing maybe?
Tyler82toy
  • Male Posts: 81
  • Member since Jun '09
« Reply #4 on: Aug 21, 2010, 06:25:47 AM »
possible fuel filter maybe
superkaliguy [OP]
« Reply #5 on: Aug 21, 2010, 09:19:16 AM »
I took the black housing thing off the carburator, i found that the carb is not responding to the throttle, when u push on the throttle nothing happens. no gas or movement in the barrels so i think i might have a bad carb. thanks you for assists, and comments. when i find out the problem i will give more info
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
« Reply #6 on: Aug 21, 2010, 11:14:54 AM »
try rebuilding your carb, it almost sounds like it is flooding.  But, if you have no movement in the carb... who knows.  Does the truck smell like it is running rich for the little bit that it is running?
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
« Reply #7 on: Aug 21, 2010, 11:16:18 AM »
what if you put some gas in the barrells?  does it run at all then?  just don't burn yourself
Tofudude
  • Turtle Points: -31
  • Member since Jun '10
« Reply #8 on: Aug 21, 2010, 11:35:37 PM »
Its either your ECU which controls the automatic choke or your carb is stuck with the choke open/closed. i had a similar problem
  • Turtle Points: 1032
  • Male Posts: 9,752
  • Member since Oct '04
« Reply #9 on: Aug 22, 2010, 12:17:06 AM »
You can't say "it's either a or b" in this situation.  Too many variables, too many possibilities.  Really sounds like a fuel delivery issue.
superkaliguy [OP]
« Reply #10 on: Aug 22, 2010, 08:25:27 AM »
when you push the throttle u\your suppose to see the choke barrel move, but there is no play. nothing moves and u would hear the mechanical fuel pump, pump fuel into the carb. but there is no fuel too. when you press the gas pedal you would normaly feel a little pressure, but now the gas pedal feels like it has no pressure or tension.
superkaliguy [OP]
« Reply #11 on: Aug 22, 2010, 03:23:51 PM »
i looked around the carb and i was messing around with it and i came across that thing on the throttle
that silver lever, the red arrow is pointing too, if i put a screw driver on the bottom to lift ip up it keeps the car running, the higher i lift the more it revs up. but if i remove it the engines stall and dies, so is there a way that i can adjust to keep it up. Or any body knows what is happening?
« Last Edit: Aug 22, 2010, 03:31:25 PM by superkaliguy »
  • Male Posts: 9,752
« Reply #12 on: Aug 24, 2010, 12:30:34 AM »
The little screw right next to your arrow is your idle speed screw  ;)  Have you checked to see if your throttle cable is even hooked up?
superkaliguy [OP]
« Reply #13 on: Sep 02, 2010, 08:07:36 PM »
i thought the motor was a 84, but it was a 82. The carb is bad, needs rebuilt or a replacement. If anybody from the fresno area knows a shop that rebuilds carbs lmk. or have a good running one for sale lmk. thank you
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #14 on: Sep 04, 2010, 12:46:14 AM »
Rebuild it yourself, its easy. Only thing that a lil hard is rembering all the parts, but if u worried just take pics. Ive taken one apart, dont know what everything was, I just cleaned it all up real good, and put it back together how the book showed. Worked perfect after that. The kit was like 18 bucks from napa. I charge my buddies 40 bucks to do there carb, im sure a shop is gonna charge u around 250-300. I called a shop way back in the day for a quote on one, 500 bucks, thats why i just learned to rebuild mine.
superkaliguy [OP]
« Reply #15 on: Sep 04, 2010, 08:31:52 AM »
i'll have to look into that, not much of a carb person. When it comes down to carbs, i'm a noob
superkaliguy [OP]
« Reply #16 on: Sep 18, 2010, 06:55:04 AM »
yeah, narrowed down that i had a bad carb! i bought a rebuilt one from a shop, instal it and now it runs great! Thanks for all the support :thumbs: :thumbs:
Last post Nov 14, 2005, 09:49:14 PM
by ...................................
Last post Jul 28, 2005, 11:21:58 AM
by BIGSKY70
Last post May 07, 2006, 09:09:12 AM
by Shamb
Last post Dec 28, 2010, 05:25:27 PM
by baggedyoda
Last post Feb 05, 2012, 12:31:19 PM
by toyotamobing
