Author Topic: Can you put an electric speedo sensor on a tcase designed for a cable?  (Read 2576 times)
snowplow
  • Male Posts: 257
  • Member since Aug '06
  • smoke tires not drugs
Just wondering if anyone knows if you can put an electric speedo pickup (I think its called a VSS?) on a transfer case designed for a cable?  :usa:
DC
Early
  • Turtle Points: 67
  • Male Posts: 470
  • Member since Oct '09
  • The Buddhas ridin shotie
yea, you can either use part of your cable one and marlin's kit
http://www.marlincrawler.com/transfer-case/parts-upgrade/vehicle-speed-sensor-mci
or there were a few toyotas that came with a gear case and pulse speedo, so there is a factory part, but spendy
http://www.marlincrawler.com/transfer-case/parts-upgrade/vehicle-speed-sensor-oem
I have been running my marlin kit for 2 years with no problems.
edit: there are a few other that make one too, i think inchworm and sky maybe?
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
Early
  • Turtle Points: 67
  • Male Posts: 470
snowplow [OP]
  • Male Posts: 257
So my truck is a 93 and had a gear case, so am I correct that I could beg for my original one back and just bolt it in!? That would be SWEEEET!
Early
  • Turtle Points: 67
  • Male Posts: 470
it should look like the lower one from your quote. my 94 22re had a chain drive case and the vss was different size. its possible though.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Some of the later models 4 cylinders came with a chain drive t-case, but I think most came with a gear drive case. If it was a gear drive case, why did you get rid of it?
snowplow [OP]
  • Male Posts: 257
418w small block ford, NP435 granny 4 speed, A/A adapter to older topshift style tcase (so I had a shifter handle).
Early
  • Turtle Points: 67
  • Male Posts: 470
You had a forward shift before? If your sure it was a chain case then it should work. They look similar though. im real happy with my marlin unit. and you probably know someone with half a cable unit they don't need if you don't have one.
snowplow [OP]
  • Male Posts: 257
I thought I identified it as a gear case before, but I could be wrong? I'll go pull the vss off and just see if it fits, that oughta tell me all I need to know it sounds like.
Last post Dec 02, 2003, 10:45:18 PM
by CruzrDave
Last post Jan 10, 2005, 11:27:13 PM
by kneedownnate
Last post May 03, 2006, 10:30:37 PM
by Clifcattankass
Last post Dec 14, 2006, 07:13:32 AM
by Neoworm
Last post Jul 17, 2008, 06:45:12 AM
by beyondlogic
