Poll
do the swap?
yes
8 (100%)
no
0 (0%)
Total Members Voted: 8
Author Topic: Sr5 gauge cluster help  (Read 1716 times)
Ancich
  • Turtle Points: -2
  • Male Posts: 42
  • Member since Jul '10
« on: Aug 02, 2010, 10:39:48 PM »
ok, so i got a sr5 gauge cluster, i want it for the built in tach :), how can i tell if my truck is wired for a tach or not? and how do i change the mileage :lipsrsealed:, any help would be gladly appreciated!! :turtle:
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
Re: Sr5 gauge cluster help
« Reply #1 on: Aug 02, 2010, 11:05:45 PM »
K to tell if its wired for a tac pop out your cluster thats in it and see if the very far plug its light blue has 3 wires if not you need to add one, and change out the oil sender. for the miles just pop off the cover shield plastic, and take out the 4 screws that hold in the speedo and move the miles very carefully they will roll with a lil force or you can pop out the little rod and roll them make sure to put the keeps back in.
86 mini truck 18" rays
09 highlander
70 suburban
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #2 on: Aug 02, 2010, 11:10:08 PM »
also check this out: http://board.marlincrawler.com/index.php?topic=72088.msg862838#msg862838
NOT TO RUB IT IN, BUT SEARCHING GOES ALONG WAY HERE AND KEEPS PEOPLE OFF YOUR BACK.
09 highlander
70 suburban
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
« Reply #3 on: Aug 03, 2010, 07:17:04 AM »
tach is easy, one wire to the plug off of your coil
Brandon Miller
RCRC, Sacramento, CA
shanotech
  • Male Posts: 5
  • Member since Aug '11
« Reply #4 on: Aug 20, 2011, 11:12:23 PM »
Just make sure to change the oil sensor before starting the car, or you will probably fry your tech oil pressure gauge!
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
« Reply #5 on: Aug 21, 2011, 10:20:19 PM »
On mine I just swapped it in and everything worked, I unplugged to oil switch though.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #6 on: Aug 22, 2011, 12:58:32 AM »
Sometimes the tach is already hooked up and sometimes it isn't, other than that the oil sensor is the big thing to change out. Everything else is the same.
Last post Apr 26, 2003, 03:11:34 AM
by supratruck
Last post Jan 25, 2005, 06:49:31 PM
by Weldo
Last post Nov 22, 2005, 11:23:11 AM
by bjack
Last post Jul 17, 2008, 06:45:12 AM
by beyondlogic
Last post Feb 18, 2021, 10:15:54 AM
by accountant_mechanic_
