Author Topic: cluster swap  (Read 2499 times)
LD
  • Turtle Points: -2
  • Male Posts: 286
  • Member since Feb '10
cluster swap
« on: Jul 07, 2010, 03:47:43 PM »
ok i have searched but cant find anything. When switching to a sr5 cluster do i haveto run a wire for the volt guage or is it good to go just plug it in. And I found the pinout numbers showing sr5 and dlx and the pinout numbers are not all the same how does it still work when i swap it out.  Hope you guys know what I am trying to say.  :confused:
The best place to find a helping hand is at the end of your arm.
DanGT86
  • Male Posts: 7
  • Member since Oct '09
Re: cluster swap
« Reply #1 on: Jul 08, 2010, 03:04:09 PM »
I switched from a 90 4cyl cluster to a v6 cluster from a 4runner at the junkyard.  Everything worked accept for the oil pressure indicator.  It is pegged all of the time on the new cluster. I figured the 4cyl didnt have a sender for a gauge with any range.  Just an idiot light. The only thing weird I had to do was turn the adjuster for the tach to be right.
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
  • Member since Dec '06
Re: cluster swap
« Reply #2 on: Jul 08, 2010, 03:06:40 PM »
I don't mean to hi jack but how exactly do you turn the adjuster on a toyota tach?
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: cluster swap
« Reply #3 on: Jul 08, 2010, 03:17:10 PM »
You have to swap out the oil pressure sender or you will burn up the oil pressure gauge. You adjust the toyota tach you take it apart and there is a lil spring/arm you move IIRC. You might also have to wire in for the tachometer. And if your a auto you might have to swap some wires for the volt meter to work right.
86 mini truck 18" rays
09 highlander
70 suburban
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
Re: cluster swap
« Reply #4 on: Jul 08, 2010, 03:19:18 PM »
My truck has a 4cl cluster in it with a tach, it's factory but the tach is off by about 1000 rpms.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: cluster swap
« Reply #5 on: Jul 08, 2010, 03:27:36 PM »
v6 cluster maybe.
09 highlander
70 suburban
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: cluster swap
« Reply #6 on: Jul 08, 2010, 03:29:37 PM »
09 highlander
70 suburban
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
Re: cluster swap
« Reply #7 on: Jul 08, 2010, 05:51:23 PM »
Sweet... Thanks bro...
gtoyonrocks
  • Turtle Points: 2
  • Male Posts: 977
Re: cluster swap
« Reply #8 on: Jul 08, 2010, 06:15:11 PM »
Looks pretty simple. I am going to try this out as soon as I get home.
LD [OP]
  • Turtle Points: -2
  • Male Posts: 286
Re: cluster swap
« Reply #9 on: Jul 08, 2010, 08:28:17 PM »
I know about the oil sender and tach. Thats it though. Seems to simple
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: cluster swap
« Reply #10 on: Jul 08, 2010, 10:01:45 PM »
thats it. I have a 87 base modle got a sr5 cluster put in the oil pressure sender and wired up a tachometer every thing works fine.
09 highlander
70 suburban
83MT
  • Turtle Points: -23
  • Member since Jun '08
Re: cluster swap
« Reply #11 on: Jul 08, 2010, 10:28:15 PM »
Really depends on the year of your truck...
Zach
I like Yotatech
LD [OP]
  • Turtle Points: -2
  • Male Posts: 286
Re: cluster swap
« Reply #12 on: Jul 08, 2010, 10:33:33 PM »
well mines a 86. So lets hope everything works that easy. :crossed: I should be getting the cluster soon so i will let you guys know how it goes
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: cluster swap
« Reply #13 on: Jul 08, 2010, 10:46:09 PM »
is your truck efi or carb? and what is the cluster from?
09 highlander
70 suburban
LD [OP]
  • Turtle Points: -2
  • Male Posts: 286
Re: cluster swap
« Reply #14 on: Jul 09, 2010, 09:57:31 PM »
Efi
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: cluster swap
« Reply #15 on: Jul 12, 2010, 03:08:32 PM »
both efi then you should be golden.
09 highlander
70 suburban
LD [OP]
  • Turtle Points: -2
  • Male Posts: 286
Re: cluster swap
« Reply #16 on: Jul 18, 2010, 01:48:23 PM »
Here it is I got it yesterday from Bog-toy hooked it up today i got lucky it had a wire ran all the way to the plug for the tach and all i had to do is plug it in and go. Need to get a new oil sender i have the old one unplugged tell tomorrow. Looks alot better than the old one. I also ordered a bearing kit for my 3rd member but when i got it apart the previous owner swapped a v6 3rd in and I was not aware of that so had to take them back and get v6 bearings so my rig sits in pieces tell tuesday.  :(
Heres a pic of the 4cyl and the v6 pinion bearing. A little bigger
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: cluster swap
« Reply #17 on: Jul 18, 2010, 02:21:22 PM »
oil senders are spendy from $35-70 from what I found out new. Go to the junkyard and get a used one.
09 highlander
70 suburban
LD [OP]
  • Turtle Points: -2
  • Male Posts: 286
Re: cluster swap
« Reply #18 on: Jul 18, 2010, 02:25:26 PM »
Thats what im planning on doing. But its been hot here so im going tomorrow morning when its cool
Last post Apr 02, 2006, 07:23:24 PM
by 11 Bravo
Last post Feb 12, 2007, 05:19:47 PM
by 8D3TOY
Last post Jul 07, 2007, 05:45:31 PM
by 8D3TOY
Last post Sep 03, 2008, 11:16:36 AM
by KDXSR5
Last post Feb 17, 2011, 03:07:44 PM
by Snowtoy
