Author Topic: 4 speed to 5 Speed???  (Read 3149 times)
awhotrods
  • Turtle Points: 154
  • Male Posts: 1,203
  • Member since Nov '04
« on: Dec 17, 2004, 10:29:15 AM »
My 82 4WD came with the cast iron 4 speed tranny, i want to swap it out for a 5 speed, what years will bolt in?  I am assuming I will have to move the crossmember.  Thanks for any advice!
madmax21tm
  • Turtle Points: 5
  • Male Posts: 15
  • Member since Apr '04
  • Groovy!!!
Re: 4 speed to 5 Speed???
« Reply #1 on: Dec 17, 2004, 12:30:57 PM »
Sounds like you have a L45 4 speed. The L50, L52 and L52HD 5 speeds should bolt right in, I think that they are very close to the same housing. If I know what I'm talking about these four trannys are all 20.75" long and are interchangable. This would be the easiest and most simple way to get a 5spd. The strongest is the L52HD, (also Marlin can upgrade the L50 to a L52), check out the transmissions page on the marlincrawler website. Look up the L45(yours), L50, L52 and L52HD and do a little comparing. Also check out Marlins profile and look at what he's running.  :sly:
I just looked at the MC webpage and the years are;
L45 '81-'82 carb,
L50 '81-'82 carb,
L52 '83 carb,
L52HD '81-'83 carb.
Hope this helps a little. :crossed:
« Last Edit: Dec 17, 2004, 12:41:36 PM by madmax21tm »
Some call it junk, I call it inventory. :flamer:
awhotrods [OP]
  • Male Posts: 1,203
« Reply #2 on: Dec 17, 2004, 01:24:48 PM »
thanks for the info  :beerchug:
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #3 on: Dec 18, 2004, 08:17:57 PM »
Things you might need to change- crossmember placing, both drivelines, maybe speedo, cut a hole in the floorboard for the t-case shifter, it will be farther back if you plan on keeping the top shift.  then you need to make a plate to cover the hole on the top of the tranny.
MidgetMike
  • Turtle Points: 55
  • Male Posts: 668
  • Member since Sep '04
  • My 83 soon to be the sh%*
« Reply #4 on: Dec 19, 2004, 10:27:10 AM »
If you get a forward shift G52,G54, or certain W56's, your shifters will nut move but your tranny mount will need to be moved. I just put a G54 in my 83 replacing my L52. the shifters are in the same location as the L52 but the tranny is a few inches longerbetween the bell housing and T case I had too move my T case mount a few inches. I welded my crossmember on as a temp fix while I make a new mount. The nice thing about the forward shift is your shifters are in the same location but you get a few more inches for your  driveline angle, and save some space on your floor board if you do dual cases.  :turtle:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Dec 23, 2004, 05:56:46 PM »
dude,  your tranny is identical to the L50-52's  you can make your tranny a 5 spd simply by adding the fifth gear, im sure marlin can help you with this
L52 is a direct bolt in upgraded replacement, no cutting bending or modifying at all
kyle_22r
  • Turtle Points: 530
  • Male Posts: 1,233
  • Member since Dec '03
  • yellow beast
« Reply #6 on: Dec 23, 2004, 10:39:16 PM »
you're lucky you have the L45...i've got the L43 and you have to change a bunch of stuff...at least it bolts right in with the right parts!
i've got an L50/L52(i'll figure it out when it blows up) in the garage, just gotta power wash it and finish building the new 22R(currently a short block) :ladys-man:
FATB0Y
  • Male Posts: 2,803
    • fatboy on my space.com
« Reply #7 on: Dec 23, 2004, 10:46:37 PM »
Merry Christmas everyone  :santa:
Last post Jul 29, 2002, 04:07:55 AM
by hawaii500_1999
Last post Jan 24, 2004, 05:27:12 PM
by thebogs
Last post Sep 21, 2020, 08:58:15 AM
by Hal Smythe
Last post Nov 16, 2020, 12:00:19 PM
by djamison
Last post Jan 13, 2024, 07:48:17 AM
by Rocksurfer
