Author Topic: 98 to 99 4 runner gauge cluster swap  (Read 2400 times)
Capt. Crawler
  • Turtle Points: 199
  • Member since Oct '06
« on: Jun 05, 2010, 11:48:46 AM »
 :inthedark: My 4 runner didnt have a gauge cluster when purchased so I've got one from a 99 Limited 4 runner
 Although the plugs~ plug in the gauges dont work???
 I did a search but no luck finding the " pinouts" as I did for my first generation gauge up grade?
For the record, here are the pinout of SR5 vs non-SR5 gauge for 83:
SR5     non-SR5     wire color       function
 1        1            GY           Right turn signal indicator
 2
 3        3            BR (B BR)    Speed sensor (-) ground
 4        6            GL           Speed sensor (+)
 5
 6
 7        23           YG           Water temp gauge
 8        9            RW           Panel lights (+)
 9        15           YR           Fuel Gauge
10        12           Y            Ignition switched power
11        21           YB           Oil Pressure switch (idiot light)
12        22           YW           Charge (idiot light)
13        14           WB           Ground
14                                  Tach input - must be wired to igniter
                                                 yellow
15        17           GB           Left turn signal indicator
16        16           RB           Panel lights (-)
17
18
19        11           G            4WD
20
21        19           BY           Seat belt
22
23        13           RG           High Beam
24        20           GW           Brake
80YOTA4X4
  • Turtle Points: 2
  • Male Posts: 151
  • Member since Jan '09
Re: 98 to 99 4 runner gauge cluster swap
« Reply #1 on: Jun 08, 2010, 11:49:48 PM »
http://www.hunt4steve.com/OR/99_4Runner_Ltd/Fsm/combination_meter.jpg
Not sure what years this is for or if it has all years in one listing. but at least its a start
MC387
  • Turtle Points: -4
  • Member since Dec '06
« Reply #2 on: Jun 16, 2010, 12:30:08 PM »
All data has the diagrams.  Our library has them.  Maybe yours does too.  If not maybe a local shop has them or I could fax them too you.
Capt. Crawler [OP]
« Reply #3 on: Mar 26, 2011, 05:34:32 PM »
ttt
Last post Apr 02, 2006, 07:23:24 PM
by 11 Bravo
Last post Jun 13, 2008, 01:18:44 PM
by Plekto
Last post Jun 26, 2008, 01:38:25 AM
by Toymin8r
Last post Jul 17, 2008, 06:45:12 AM
by beyondlogic
Last post Apr 03, 2009, 08:36:59 PM
by 4runner17
