Author Topic: Toyota SR5 and non SR5  (Read 1647 times)
84krawler
  • Turtle Points: 108
  • Male Posts: 177
  • Member since Jan '10
« on: Jun 03, 2010, 08:52:56 PM »
I was wondering if it was possible to put the whole gauge cluster from a SR5 into another that doesnt have a tachometer if the wiring would work or just plug in to operate the tach :dunno:
Greiner
  • Male Posts: 82
  • Member since Aug '09
Re: Toyota SR5 and non SR5
« Reply #1 on: Jun 03, 2010, 08:59:55 PM »
ya its possible heres a link that explains it all  :thumbs:
http://www.siestaoffroad.com/clustertech.html
84krawler [OP]
  • Male Posts: 177
« Reply #2 on: Jun 03, 2010, 09:04:19 PM »
Thanks man dont like the lame gauges with no oil tach or volts :clap2:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #3 on: Jun 03, 2010, 09:10:54 PM »
Everything would be plug in, but you need to get the SR5 sending units too. You may also need to hook up the tach.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
« Reply #4 on: Jun 03, 2010, 09:13:50 PM »
You need to change the oil pressure sender for sure. some trucks you don't need to wire in the tac some you do.
86 mini truck 18" rays
09 highlander
70 suburban
84krawler [OP]
  • Male Posts: 177
« Reply #5 on: Jun 03, 2010, 09:32:12 PM »
i already got the new oil pressure sender in it i'll look and see if the wire is there for the tach if it doesnt have it should it be hard to install one
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #6 on: Jun 03, 2010, 10:08:15 PM »
nope its pretty easy. What year? If its a second gen there is a blue plug that goes to the cluster on the left side. there is 2 yellow wires there is one with a green tracer you need to install the tac wire next to it on slot 7. Its the slot on the part with the clip on it. right next to the break in the connector.
09 highlander
70 suburban
84krawler [OP]
  • Male Posts: 177
« Reply #7 on: Jun 03, 2010, 11:49:17 PM »
its an 84
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #8 on: Jun 04, 2010, 06:21:15 AM »
should still be the same then. 2nd gens are 84-88/89
09 highlander
70 suburban
Last post Jun 12, 2006, 10:04:09 PM
by Skim
Last post Aug 09, 2007, 04:31:09 PM
by gtoyonrocks
Last post Nov 14, 2008, 05:05:31 AM
by focushere
Last post Apr 22, 2023, 04:33:47 PM
by lone walker
Last post Aug 02, 2024, 01:27:17 AM
by bridgetkeble
