http://board.marlincrawler.com/index.php?topic=19275.0
Yes i've read thru that but where does it answer my question, "Can I bolt up a 3RZ to my 22re A340 bell housing?" I know I could get a bell housing from a 3RZ auto but why if mine will work?
Yeah I've seen the bell housing for the manual, I was thinking that was for a trans that wasn't offered behind a 22r?
I've got an " A340E" available out of a '98 4 Runner. 2 Wheel Drive!!!
Even if you have an F your still gonna end up needing an adapter to mount a gear driven tcase if you plan to wheel the truck. Autos make it kind of messy.
I mean if you leave the auto in D position it will shift on you when u dont want it to. So you move the shifter to 2 and it locks it in 2nd gear. If your crawling you DONT want it to shift. Let alone it will make it hard to gain traction but it also can do damage to the trans since it will be under a lot more load.
Started by Rollover Roy Engine
Started by wood General 4WD Discussion
Started by SnowKat Toyota Pickup/4Runner Tech 1979-95
Started by YotaCrawler530 General 4WD Discussion
Started by natdog73 Newbie Questions
