Author Topic: 22R valve cover leak  (Read 11691 times)
David
  • Turtle Points: 218
  • Male Posts: 263
  • Member since Jan '03
  • I love Marlin Crawler!
« on: May 23, 2010, 09:27:53 PM »
83' 22R
My valve cover leaks a bunch out the rear center where the rubber half circle plug sits.
Everything is new, came in a set.
The plug does not want to go all the way down to sit flush with the surface and tightening the cover nuts does not crush it down far enough. Anyone else had this problem with replacements and what did you do? I didn't want to use sealant but may have to.
Thanks for any advice.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
Re: 22R valve cover leak
« Reply #1 on: May 23, 2010, 10:36:20 PM »
The gasket is leaking? Get a new one from toyota. or if its just the plug for the top of the valve cover get a new one. was any of the old gasket left on there?
86 mini truck 18" rays
09 highlander
70 suburban
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #2 on: May 24, 2010, 12:07:55 AM »
Do you have the wrong studs on the rockers?  Some are cut to bottom out earlier than others, maybe you swapped them at some point and it's not allowing the cover to bolt down all the way.  Otherwise I'd think you don't have it in there square.
David [OP]
  • Male Posts: 263
« Reply #3 on: May 24, 2010, 07:35:50 AM »
New valve cover gasget and new rubber inserts for the cover studs. It is not leaking from the new gasget or the stud grommets but from the rubber half circle insert at the back of the head and it's new.
Everything was clean, no residue at all. I've changed this thing out a couple of times and can't get it to stop leaking from the rear at that rubber insert. Really a pretty healthy leak too, can't drive it or I'll loose all my oil. The studs allow the cover to seat well, it's just leaking at that insert, well not really leaking but running out once warmed up.
I'm going out this morning and give it another try.
Thanks guys.
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #4 on: May 24, 2010, 01:05:43 PM »
Add RTV to the groove in the half-moon plug...............
David [OP]
  • Male Posts: 263
« Reply #5 on: May 24, 2010, 09:45:27 PM »
Thats what I ended up doing, didn't want the mess next time I take it off but at least the leak and the mess is stopped. Thanks
  • Male Posts: 9,757
« Reply #6 on: May 25, 2010, 12:58:11 AM »
I think you completely missed what I was saying.  If your nuts bottom out on your studs before the rear half moon is squished down, it'll never seal.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #7 on: May 25, 2010, 01:13:04 AM »
I 2nd that. Thats why I asked my first questions. Some people just don't take the time to read.
09 highlander
70 suburban
David [OP]
  • Male Posts: 263
« Reply #8 on: May 25, 2010, 08:08:06 AM »
(Some people just don't take the time to read.)  And just how did you surmise that, Vulcan mind probe perhaps??  :rofl2:
I did take the time to read the messages. The nuts were not bottomed out, that was not the problem. The problem is the half circle rubber is too big for the seat and stays above the sealing surface of the head. Much RTV and it finally sealed. Thank you for your help.
« Last Edit: May 25, 2010, 08:14:48 AM by David »
  • Male Posts: 9,757
« Reply #9 on: May 25, 2010, 12:16:48 PM »
I hope for your sake it doesn't leak, but dollars to donuts it's gonna leak like any bandaid will.  The half moons always stick up just a little but compress, unless you don't line up the inside and outside lip, in which case they don't seat.
If you're comfortable with your bandaid that's cool, but I strongly suggest you remove it and figure out just why it's not fully seating, since there is a reason and it's probably a simple one  :twocents:
David [OP]
  • Male Posts: 263
« Reply #10 on: May 25, 2010, 08:36:56 PM »
Thank you for that advice and I'm going to heed it because I'm not happy with the bandaid either.  I bought a Toyota cover gasget and it was the wrong one so I used a Fel-Pro set instead of making the long trip to the dealer again, not a great choice. I'm going back to Toyota and get a replacement gasget and another set of half moons and some alt brushes.
Thanks again for the advice guys.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
« Reply #11 on: May 25, 2010, 08:57:24 PM »
welcome I was not trying to be rude. I just don't have the skils to think things out right like others and go in to full detail of it. To much pirate and honda-tech bs for me. I need to learn to be nicer. I'm sorry.
09 highlander
70 suburban
David [OP]
  • Male Posts: 263
« Reply #12 on: May 26, 2010, 08:59:21 AM »
Hey fade, thank you but no need to apologize for anything you said it was no big deal. It would take considerably more than a small comment to rile me up. I was just poke'n fun with the Vulcan comment, it's all good.
Dave
  • Male Posts: 9,757
« Reply #13 on: May 27, 2010, 01:26:58 AM »
Excellent call, best $10-15 you'll spend at the dealer!  Hardest part of the swap is pulling the alt out.  I'm always a little irritated when I hear of people buying a kragen/autozone alternator, then crying when it craps out prematurely.
Uncle Jesse
  • Turtle Points: 21
  • Male Posts: 375
« Reply #14 on: May 31, 2010, 05:24:22 PM »
For an extra few bucks at the dealer you can pick up some starter contacts as well
Beateryota666
  • Turtle Points: -17
  • Member since Feb '10
« Reply #15 on: Jun 23, 2010, 10:07:03 AM »
did you check and make sure there were no cracks up the back of the valve cover?if you cranked on it in an attempt to seal the leak its possible to have cracked the cover.just an idea.best of luck
  • Male Posts: 9,757
« Reply #16 on: Jun 23, 2010, 10:35:45 AM »
I'd have to think if you cranked down on the nuts that hard they'd bottom out on the studs far before cracking the cover, and the weak point on the cover would likely be right around the nuts.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
« Reply #17 on: Jun 23, 2010, 11:56:11 AM »
Yeah ive pulled out 3 NEW kragen alts , to install used toyota ones with new brushes. People think im crazy. Never had a prob yet, had plenty of problems with kragen starters and alternators tho....
David [OP]
  • Male Posts: 263
« Reply #18 on: Jun 23, 2010, 12:27:00 PM »
Problem was solved with a new gasget set from the Toyota dealer. I did check for cracks and found none. I guess that is a lesson learned, don't scrimp on Yota stuff, buy the best first and be done with it.
Thanks for all the advice you guys threw my way. (:
Last post Apr 10, 2006, 07:17:28 AM
by MiniSimp
Last post Mar 20, 2008, 09:38:36 PM
by Skim
Last post Jul 25, 2010, 12:53:36 PM
by slick
Last post Mar 10, 2016, 08:53:45 PM
by Lobo176
Last post Oct 10, 2022, 01:57:31 AM
by Gnarly4X
