1985 yota ext cab efi,
i was going to go with battery cut off and trying to do a igniton switch too... you guys got any ideas,,,, right now ive been having issue with starting so i have push start next to key ignition which is a straight shot with a fuse between it and battery too..... so even if truck is off if you push the button it will try kick over... basically i want to do like i said battery cut off and do ignition,
so,,,, in order to start you need key still but when i flip swtch "when sticking key in and turing you get notihing untill you flip switch, then it gets power.... i know i got to tap into key swtich just wondering if you guys done it
