Author Topic: how do you determine if your rear axle is 2.5" or 3.75" ???  (Read 2289 times)
PastorKerry
  • Male Posts: 51
  • Member since Apr '10
  • making the most of every opportunity
    • Motorsports Squared (use "kmack5" for your discount at checkout)
I am looking at adding a block kit to the rear end just to level my 1986 4runner that is bone stock.
how do I determine if the rear axle is 2.5" or 3.75"
Appears that most kits are for either a 2.5" or 3.75" rear axle... that is on the Tuff Country website.
Pastor Kerry
http://www.visionxstore.com/ (use "kmack5" for your 5% discount at checkout)
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
tape measure
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
  • Momentum Man
  • Turtle Points: 521
  • Male Posts: 13,821
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
I don't like block lifts, it creates spring wrap that will just cause increased stress on the springs, ujoints, etc., etc. If you do go with one make sure you get a steel set, the aluminum blocks will wear from the torque and loosen in short order. A shackle lift which is easier and just as cheap would be your best option until you can get a better set of springs. It is fairly common for 4Runners to sag due to the extra pounds they carry with the top. Now I have had a truck with blocks before but I bought it that way and I did feel the difference over a rig without. I think they are refering to the block thickness as to the 2.5 or 3.5. You can pick those up at any 4x4 shop, 4 Wheel Parts is in Compton not to far from you on the 91 and Wilmington.
« Last Edit: May 03, 2010, 02:30:37 AM by Rocksurfer »
Snowtoy
  • Turtle Points: 1001
  • Male Posts: 2,521
  • Member since Sep '03
Lift blocks are designed for lifting a vehicle, not resolving sagging springs, same for extended shackles.  The best thing to do will be to rebuild them, and you will get a much better ride by adding another main leaf than going w/blocks or a shackle.
  • Turtle Points: 1425
  • Male Posts: 22,629
  • Solid axle Toys Rule ! ! !
Kerry, its very easy to add a leaf to your spring packs.  do you have basic hand tools??  4 inch grinder??  if so you can easily install a long leaf to your packs,  you can easily get some from ruff country and many other vendors but make sure they are LONG leaves,  personally i much prefer getting some springs from the junk yard.  either some toyota springs or 2wd chevy S10 springs or 2wd F150 springs basically any leaf spring set thats 2 1/2 inches wide and has good arch to them,  many "add a leaf" kits are short very thick leaves that end up bending the original springs,  using the longest leaf you can find will offer a better ride and more lift.
PastorKerry [OP]
  • Male Posts: 51
Thanks for the tip.  I'll look into the cost of rebuilding a set of springs as well as adding a leaf.
Thanks!
Pastor Kerry
PastorKerry [OP]
  • Male Posts: 51
Really good insight.  Yes, I have basic hand tools, grinder, compressor, impact wrenches, etc...  Just don't have a welder or cutting torch.... YET... Looking for a good mig welder and torch.
I'll find a local junk yard and look for "yota springs or 2wd chevy S10 springs or 2wd F150"
How long of a leaf am I looking for?
And where in the pack does it go? top, middle, lower???
Several others had mentioned fabbing up a couple of shackles 9" long with holes 7" between bolts.  So I fabbed those up today... Now I am thinking I might not put them on after reading a few of the newer posts.
The shackles that are on there are not the originals.  They are 4" between bolts, but it looks like they were made from a cut of old spring.  1/4" x 2 1/2" x 6"  They are 2 pieces and are not welded together.  The bolt pattern looks to be stock distance between bolts at 4"...  and the bolts look to be 1/2" threaded bolts.
Pastor Kerry
  • Momentum Man
  • Lego Enforcement
Sure you could add another leaf to the pack, which is basically doing the same as any stop-gap measure, in the end the only real cure would be to replace the fatigued springs with a new set. Even having springs re-ached will weaken them causing failure in the future. If they were not old and fatigued I would suggest adding leafs but a fatigued set will only fail in the future. It's a crap-shoot with any of the fixes on fatigued springs but the easiest, least expensive, least work, and quickest is a shackle lift. Now if he decides to go that route and add a leaf he needs to remove the flat load leaf and replace it with a long load leaf this will help to avoid a harsh ride.
PastorKerry [OP]
  • Male Posts: 51
Ok... thanks... Well I think I'll try inserting these shackles I fabbed up today and see what it looks like.
Really wanting to save as much as I can for a SAS and all the trimmings later this year.
Pastor Kerry
  • Momentum Man
  • Lego Enforcement
I got the feeling it was just a temporary fix for later and bigger mods, all the more reason to slap on some shackles and move on.
Last post Feb 16, 2007, 07:18:41 PM
by BoG-ToY
Last post Feb 05, 2008, 02:53:01 PM
by Goose
Last post Mar 09, 2008, 11:52:37 PM
by BoG-ToY
Last post Feb 02, 2009, 10:03:19 AM
by the_white_shadow
Last post Jun 29, 2020, 01:11:48 PM
by mudmaster
