Moving out of AZ i got orders to Hill AFB utah need this stuff gone or its going in the trash
All this stuff is In Tucson , AZ Pm me with any questions shipping will be on your dime
Email me or PM me either way i can ship out ASAP via PayPal transaction
Toyota head 92 2wd 22RE -- $ 100
This is a full head cam,springs,valves ect.
It has about 127K on it all stock it was running great when i took it off, i just swapped it out for a new head w/some upgrades i did get it steamed cleaned
Rear Driveshaft 84 4x4 22r--$40
Starter 93 22re 2wd -- $20
2 Exhaust EGR pipe -- $5ea
AutoMeter Ultra-Lite Analog Gauges Oil & Water Pressure
Auto Meter Ultra-Lite Analog Gauges Oil Pressure&Water -- $30 each
sizes are 2 1/16 brand new never installed
The water temp hardware is missing it just has the bulb and wire but you should be able to get the sending unit from Summit
MTX Thunder 6000 10$)C!1 Sub in box -- $50
Here is a link to specs
http://www.bizrate.com/carsubwoofers/mtx-thunder-6000-hc10-10-in-subwoofer--pid11295545/ Pioneer 200W TS-TRX800 Speakers in truck box!/s (to fit behind a single cab seats) -- $60
http://www.audioallies.com/getitem.asp?Item=TS-TRX800&Sys=GG )
Amplifirer Visonik VB210PKG worked when I removed it two years ago -- 20
http://www.sonicelectronix.com/item_3115_Visonik+Amplifier+%2B+Amp+Kit+%2B+2+10-+Subwoofers+%2B+Box+Super+Thump+Package-.html02WRX Intercooler, couple of the fins are bent but they can be straighten with a scribe no leakage -- 30
84 Toyota vents I only have the 3 in the pic - $5
Toyota Marker Lights $5
Toyota Head light holders/rings - $5
93 Toyota Door Sills - $5
Toyota headlight (1) - $5
Camper Clamps (Aluminum) I have 3 of them but only took a pic of 2 - $20
U-Bolt (1) - $5
Misc. Oil (unopened) this is stuff I will never use - Couple bucks each !&?
1 - 2 Cycle Engine oil Quaker state
1 - Outboard Engine oil (2 Cycle)
2 - Honda Suspension fluid SS-8 10W (Forks)
1 - Honda 4 Stroke Motorcycle Oil 10W-40 sj
K&N cleaner & Oil - 20 bucks
One of the small ones are full the other 2 are about half full
[/quote]
