Author Topic: 3.4 misfiring  (Read 4929 times)
toyofan7987
  • Male Posts: 124
  • Member since Jan '07
  • yoter boy till i die
3.4 misfiring
« on: Apr 11, 2010, 12:57:44 PM »
my 97 t100 3.4 keeps throwing a code. cylinder 2 misfire. have changed oil spark plugs and the coil and its still doing it??? any idea?
yotaneck13
  • Mr. Right NOW
  • Turtle Points: -52
  • Male Posts: 2,300
  • Member since Nov '09
  • MR. RIGHT NOW
Re: 3.4 misfiring
« Reply #1 on: May 01, 2010, 07:22:01 PM »
un hook battery unplug ecu let it sit overnight then try it see if it resets if it does not pull the spark plug and check to see if the gap  is correct also did u replace the coil pack its self or just the wire running from no 1 to no2?
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
Re: 3.4 misfiring
« Reply #2 on: May 01, 2010, 07:28:39 PM »
check your 02 sensor.
86 mini truck 18" rays
09 highlander
70 suburban
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
Re: 3.4 misfiring
« Reply #3 on: May 01, 2010, 08:39:25 PM »
o2 wont make a misfire cide trip i dont even run my o2's and it runs fine
fade
  • Turtle Points: -9
  • Male Posts: 1,018
Re: 3.4 misfiring
« Reply #4 on: May 01, 2010, 08:52:38 PM »
some times if they are really fouled up they do missfire and sound like a wrx. I'd check your coil packs also. And grounds.
09 highlander
70 suburban
Offroadassassin
  • Turtle Points: -1
  • Male Posts: 51
  • Member since Jan '11
Re: 3.4 misfiring
« Reply #5 on: Jan 24, 2011, 05:31:40 PM »
My truck is doing the same thing . i replaced spark plugs, the plug wires, and the coils. let me know if you figured yours out
E YOTA
  • Male Posts: 690
  • Member since Jan '04
Re: 3.4 misfiring
« Reply #6 on: Jan 25, 2011, 07:43:52 PM »
there might be water leaking into that cylinder, thats wat happened to mines...are u losing water too...jus a little bit at a time
built lastnight, crawl today...
Offroadassassin
  • Turtle Points: -1
  • Male Posts: 51
Re: 3.4 misfiring
« Reply #7 on: Jan 26, 2011, 07:06:07 PM »
No water in the oil. or does that matter? i dont think im loosing water. If thats the problem , what needs to be replaced?
superkaliguy
Re: 3.4 misfiring
« Reply #8 on: Jan 29, 2011, 09:12:10 PM »
this happen to me a while back in my 97 t100 too, i had a bad valve. I replaced it and it turn out fine afterwards
spuds015
  • Turtle Points: 123
  • Male Posts: 216
  • Member since May '10
Re: 3.4 misfiring
« Reply #9 on: Jan 29, 2011, 10:59:19 PM »
swap the stick coil that has the cyl 2 plug wire with another one, if the code moves to the new cylinder, its a coil. if not its either compression or fuel. i have same issue but on #6. new plugs new wires on mine, coils are good. compression is adequate for 236k miles so injector is only thing left
'81 pickup 5vzfe, r150f, 35's, welded 5.29's, f150 rear springs, Rears up front, TG dual adapter w/ 2.28's
Offroadassassin
  • Turtle Points: -1
  • Male Posts: 51
Re: 3.4 misfiring
« Reply #10 on: Jan 30, 2011, 09:30:44 AM »
   Thanks,  looks like i need to check the compression next.  i have 191,000 on my 04' love the motor just doesnt have all its power anymore
Offroadassassin
  • Turtle Points: -1
  • Male Posts: 51
Re: 3.4 misfiring
« Reply #11 on: Feb 10, 2011, 07:35:54 PM »
Took it to the shop. oouch!   he checked the code,  the history said miss on the 1 cylinder , and was also the reason the check engine light was on.
He took the coil out to do a leak down and compression test. said the coil had a white mark like the spark was grounding past the coil to the head or nearest  ground.
He said the compression was 165lbs. but the receipt says 170 and he tested the injector pulse, all was good.
he said it must have been the coil plug but i had the problem then replaced the plugs trying to fix it.
Do you think my #1 cylinder will arc out my new coil?
 My truck is running better than it has in a long time. He also did my timing belt, water pump, and thermostat, idler :pokinit:, all my belts and radiator hoese
« Last Edit: Feb 10, 2011, 07:47:09 PM by Offroadassassin »
spuds015
  • Male Posts: 216
Re: 3.4 misfiring
« Reply #12 on: Feb 10, 2011, 08:29:42 PM »
shouldnt arc since the coil was replaced, worn/bad coils or sticks can arc.
Offroadassassin
  • Turtle Points: -1
  • Male Posts: 51
Re: 3.4 misfiring
« Reply #13 on: Feb 13, 2011, 07:57:38 AM »
   Damn check engine light came back on ??? i bet its the number 1 misfiring
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
Re: 3.4 misfiring
« Reply #14 on: Feb 13, 2011, 09:22:38 AM »
take it back to shop and pregnant dog you jus forked out all thT MONEY and it didnt fix it they have to do it free not! thats bs i would never go back to that shop again after this is resolved :bull crap:
spuds015
  • Male Posts: 216
Re: 3.4 misfiring
« Reply #15 on: Feb 13, 2011, 10:22:43 AM »
so did it even run right the whole time with the new coil? betcha injector is going. mine ran right intermittent then stopped on a drive home.
Last post Sep 21, 2010, 05:58:12 PM
by 88yota
