Author Topic: My very first crawler build!!!!  (Read 25418 times)
b0x
  • Male Posts: 110
  • Member since Aug '09
  • 187k miles & counting
Re: My very first crawler build!!!!
« Reply #120 on: Aug 12, 2010, 07:00:02 AM »
Checked back in to see how the build is going. Looks like your working right along. Good job. Original idea with the shift knobs. :thumbsup:
:beerchug:
New Mexico wheeling
T.Rex [OP]
  • Male Posts: 164
  • Member since Mar '10
« Reply #121 on: Aug 14, 2010, 09:44:07 PM »
:beerchug:
Thanks man. When you coming down to cruces to wheel?
T.Rex [OP]
  • Male Posts: 164
« Reply #122 on: Aug 18, 2010, 07:57:15 AM »
Finally got the engine in still need to pick up q clutch and high steer but that's about it
T.Rex [OP]
  • Male Posts: 164
« Reply #123 on: Aug 18, 2010, 08:21:27 AM »
Installed some new brake lines
hilux-1983
  • Turtle Points: 3
  • Male Posts: 1,271
  • Member since Apr '09
« Reply #124 on: Aug 18, 2010, 10:26:08 AM »
While your there, cut that sway bar junk outta there  :wave:
T.Rex [OP]
  • Male Posts: 164
« Reply #125 on: Aug 18, 2010, 03:56:07 PM »
Thank you sir and will do
85toycrawler
  • Male Posts: 189
  • Member since Aug '07
« Reply #126 on: Aug 18, 2010, 07:33:13 PM »
Well that took long enough... You gotta stop workin on those Hyundai's and put in more work on the toyota...
Watch their hands. Hands kill. Smiles, frowns and other facial expressions don't (In God we trust. Everyone else keep your hands where I can see them.)
T.Rex [OP]
  • Male Posts: 164
« Reply #127 on: Aug 19, 2010, 11:03:27 AM »
i wish i could man
losttoy
  • Male Posts: 12
  • Member since Aug '10
« Reply #128 on: Aug 19, 2010, 10:22:24 PM »
hilux did you just say cut and mean something on a toyota? no way
85 single cab trk, locked front rear. 4.88's, 4.7 tcase gears. on 37's
blue_toy
  • Member since Mar '06
  • 85' w/39"s dual cases, 4.7, ARB, 63" rears, was2wd
« Reply #129 on: Sep 13, 2010, 08:39:02 AM »
Nice build will check back for more
T.Rex [OP]
  • Male Posts: 164
« Reply #130 on: Sep 13, 2010, 09:56:42 AM »
thanks, havent been working on the toy it was fall turkey season so was saving up to go out and shoot a turkey but came home with nothing so back to working on the toy. order the clutch today hopefully.
mikeaguirre922
  • Turtle Points: 8
  • Male Posts: 24
  • Member since Sep '10
« Reply #131 on: Sep 17, 2010, 01:41:55 PM »
that thing is coming along really nice considering what it looked like when you got it
1988 4runner 22re 5 speed 210,000
add a leaf, shackles, torsions tightened,
31's on black steelies, lc header, lc cold air
intake, magnaflow cat, lc muffler, lc cam, system
2 12's, 2 7" kragen hids, procomp light bar
http://s206.photobucket.com/albums/bb125/mikeaguirre922/4runner/
T.Rex [OP]
  • Male Posts: 164
« Reply #132 on: Sep 18, 2010, 02:51:14 PM »
thank you picked up a carb for it and a crossmember he made just need to order a clutch and high steer then finally on my way hopefully.
T.Rex [OP]
  • Male Posts: 164
« Reply #133 on: Sep 21, 2010, 05:08:58 PM »
figured since i had the carb in hand i would rebuild it. here it is.
first i pulled the 3 flathead screws from the base.
inorder to seperate the base from the second section you need to remove holding clip from this link.
next you remove the 5 phillis screws from the top and middle section, dont forget this one!
there will be 2 more holding clips to remove to seperate. once all apart i pulled the floats and replaced the needle. all you need is a big flathead screw driver.
make sure to remove all gasket material all i used was a razor blade. i started removing all parts from the top section perrty basic just remove parts and install in reverse order take you time and make sure that you get the springs in how they came out.
on the top section i have a electric choke it has rivits that will need to be drilled out.
heres it seperated the push rod needs to be pulled from seat and a c clip will need to be removed in order to be replaced. and when putting back together make sure you put the lever on the back of the white spacer. and all so make sure the arm facing you is placed back in the spring holder on the electric motor.
and like i said basic stuff just remember where and how it came apart heres a couple more pics that i took to help me remeber how some stuff went back together.
hope that this helps some people like i said i only took these pics to help me remember how stuff went togther sorry if there not that clear. all so make sure that you brake clean everything and work in a clean enviorment that makes it easy to find stuff if you drop is. as for the truck all i need is to get my clutch and high steer ordered.
85toycrawler
  • Male Posts: 189
« Reply #134 on: Sep 22, 2010, 11:26:35 AM »
Did you already order your propane setup? Or are you going to run it like this for awhile?
T.Rex [OP]
  • Male Posts: 164
« Reply #135 on: Sep 26, 2010, 10:21:13 AM »
no propane yet buddy gonna wait on that.
but did get a chance to install my free headers i got. talk about long tube.
T.Rex [OP]
  • Male Posts: 164
« Reply #136 on: Sep 28, 2010, 06:28:54 PM »
well picked up a homemade crossmember from my buddy who no longer needed it. had solid mounts on it so i removed the flats and had some poly bushings lying around and made them to fit.
decided that arms needed gussets too so added some
all finished and also made a trade for this long spline setup havent decided to if going on front or rear shaft.
AaronB
  • Turtle Points: 287
  • Male Posts: 2,452
  • Member since Nov '05
  • Wish I Was Crawling
« Reply #137 on: Sep 28, 2010, 11:21:03 PM »
damn! where can I get all this free stuff  :rivers:
truck is coming along nicely, good job so far  :thumbs:
gtoyonrocks
  • Male Posts: 977
« Reply #138 on: Sep 28, 2010, 11:27:56 PM »
Looking good.... I can't wait to see the final product.
1985 toy, Hybrid 20r/22r on propane, 30splines, custom built leaf packs, welded front and rear diffs, dual ultimate crawler, full hydro, full exo, flat bed, 37' mtrs
T.Rex [OP]
  • Male Posts: 164
« Reply #139 on: Oct 17, 2010, 01:26:07 PM »
wheel and deal man thats all i can say. lol
thanks me too!!!
picked up some rancho 3" add a leafs decided to just put the overload spring in and see what it feels like and sits.
got the front hanger welded on this weekend and put the springs in all leveled out
here is how its sits next to my buddys stock 94 on 31's his is so cute no lol
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #140 on: Oct 17, 2010, 01:34:07 PM »
Looks good!
T.Rex [OP]
  • Male Posts: 164
« Reply #141 on: Oct 17, 2010, 01:36:54 PM »
Looks good!
thanks feels so close but yet so far lol
T.Rex [OP]
  • Male Posts: 164
« Reply #142 on: Oct 18, 2010, 06:10:06 PM »
Well got lucky today and picked this up for $100 and installed already. 4.70's baby
T.Rex [OP]
  • Male Posts: 164
« Reply #143 on: Jan 13, 2011, 12:37:36 PM »
Hello again sorry about the wait but been super busy with the holidays and such and now I joined the army so trying to get the truck finished before I ship out to basic. I got my seats redone
And got the dash in just need to finishthe floor. Also removed that great purple tint off the windows
Also got the drive train in and all my pretty shifters.
As for what I got left is just wire in the fuel pump and connect everything and she should be running soon.
874runnertoys
  • Member since Oct '10
« Reply #144 on: Jan 13, 2011, 12:58:09 PM »
build looking good :biggthumpup:
T.Rex [OP]
  • Male Posts: 164
« Reply #145 on: Jan 13, 2011, 05:34:26 PM »
Thanks. Also got these on today
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #146 on: Jan 25, 2011, 02:15:43 PM »
looking good
bslh8tr
  • Turtle Points: 24
  • Male Posts: 61
  • Member since Jan '11
« Reply #147 on: Jan 25, 2011, 06:16:10 PM »
 :popcorn:
1986 4Runner SAS
T.Rex [OP]
  • Male Posts: 164
« Reply #148 on: Jan 26, 2011, 07:04:37 AM »
THANKS^^
GOT THE FUEL PUMP MOUNTED AND WIRED IN JUST NEED TO CONNECT THE WATER HOSES AND GET RID OF THE OLD GAS
AND GET A NEW BATTERY. SHE SHOULD BE DONE FINGERS CROSSED. BUT BEEN HELPING A BUDDY WIRE IN HIS V8 ON HIS TOY.
T.Rex [OP]
  • Male Posts: 164
« Reply #149 on: Apr 15, 2011, 06:38:17 AM »
Got the dash in
And off to my buddy's shop to button it up
Oh and my new dodge to tow it where ever lol
Last post Jan 15, 2008, 06:51:13 PM
by THK Matt
Last post Sep 30, 2010, 06:38:53 PM
by TheGaJoker
Last post Aug 11, 2012, 11:06:01 AM
by builttoabuse
Last post Jan 22, 2011, 11:44:10 AM
by yoshaleng
Last post May 27, 2014, 10:48:30 AM
by BigMike
