so here is my list of things to do...
engine fix minor p/s leak
all wiring needs to be gone through
find minor oil leak
maybe adj valves again
oil, volt gauge
adj carb if needed
driveability new wheel studs and lugnuts all the way around
new brakes front and rear
new rear brake cable
diffs, tranny, transfer case changed
lube all joints
some aftermarket heater setup "mojave"
passanger seat bolted up
sand and insulate floor
master bushing kit
alignment
locking hub bolts missing
sand and paint frame
wiper arms and blades
suspension f150 rears
12" shocks and new mount
ruf or marlin front setup
maybe 1 inch body lift
front shock hoops
86 rear axle and front wheel spacers
5.29 gears
33 12.50 r15 goodyear wrangler SA for street
37 12.50 r15 unknown for train
u bolt flips
bumpstops
this is just off the top of my head so there is probably more i know i have a long way to go for the interior, but its coming along finally!!! let me know what you guys think thanks!!
