Author Topic: My 1983 HiLux build updated  (Read 13021 times)
crazykooter
  • Turtle Points: -370
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
Re: My 1983 HiLux build
« Reply #60 on: Oct 18, 2010, 06:20:59 PM »
Looking good ! Doesnt look like you have that much left to do before its ready.
zeros215 [OP]
  • Male Posts: 68
  • Member since Mar '10
  • Its a work in progress
« Reply #61 on: Oct 26, 2010, 10:57:25 AM »
well some more delays.... as i was putting the belts and some other final touches on i noticed the adjustment pulley wasn't backing off so i will need to pick another one up before i can finally start the beast!!!!!!! so excited!
Learning every step of the way!
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
« Reply #62 on: Jan 02, 2011, 10:12:14 PM »
Any updates on this?
83 pickup, 4.88s, chevys in rear, RUF, Dual Transfers, flat belly, 3RZ swap, disc brake x4, rollin on 36" irocs
IF YOU SEE A 20' PAC WEST/CARSON FLAT BED TRAILER FOR SALE CHECK OUT THE STOLEN SECTION.  IT MIGHT BE MINE!!!!
zeros215 [OP]
  • Male Posts: 68
« Reply #63 on: Feb 01, 2011, 09:01:35 AM »
Major updates I'll be back with pictures soon.
Things done since last post: replaced sun roof, fixed vacuum lines, picked up a rear window, found door started to sand and primer, new temp exhaust, emissions test passed, new clutch slave exploded on dyno haha, grill, seats, gauges, and other little things. Been so busy working on it now that I got a job I forgot to update. New pictures coming soon
toyocrawlr
  • Turtle Points: -1
  • Male Posts: 23
  • Member since Dec '10
« Reply #64 on: Feb 06, 2011, 05:54:02 PM »
Hey bro your truck is comming out sweet im building a 83 and my lil bro is building his 89 his is a dd cause his still in school but he also goes on trails with us keep up the good work bro
zeros215 [OP]
  • Male Posts: 68
« Reply #65 on: Feb 08, 2011, 07:36:14 AM »
Awesome maybe the snow will quit long enough for me to take some update pictures haha
zeros215 [OP]
  • Male Posts: 68
« Reply #66 on: Feb 13, 2011, 12:15:26 PM »
ok people finally got some sun so I could take some updated pictures. still lots of minor things to do but it does have plates and passed emissions so im pretty happy!!
zeros215 [OP]
  • Male Posts: 68
« Reply #67 on: Feb 13, 2011, 12:17:05 PM »
zeros215 [OP]
  • Male Posts: 68
Re: My 1983 HiLux build updated
« Reply #68 on: Feb 13, 2011, 12:38:34 PM »
so here is my list of things to do...
engine :shocking:
fix minor p/s leak
all wiring needs to be gone through
find minor oil leak
maybe adj valves again
oil, volt gauge
adj carb if needed
driveability :driving:
new wheel studs and lugnuts all the way around
new brakes front and rear
new rear brake cable
diffs, tranny, transfer case changed
lube all joints
some aftermarket heater setup "mojave"
passanger seat bolted up
sand and insulate floor
master bushing kit
alignment
locking hub bolts missing
sand and paint frame
wiper arms and blades
suspension :flamer:
f150 rears
12" shocks and new mount
ruf or marlin front setup
maybe 1 inch body lift
front shock hoops
86 rear axle and front wheel spacers
5.29 gears
33 12.50 r15 goodyear wrangler SA for street
37 12.50 r15 unknown for train
u bolt flips
bumpstops
this is just off the top of my head so there is probably more i know i have a long way to go for the interior, but its coming along finally!!! let me know what you guys think thanks!!
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,336
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #69 on: Feb 13, 2011, 12:40:52 PM »
Keep up the progress, mine looked like this for a long time.
zeros215 [OP]
  • Male Posts: 68
« Reply #70 on: Feb 13, 2011, 01:57:56 PM »
Forgot to mention I'm going to get fiberglass fenders from Toyota Canada glassworks.
Last post Mar 18, 2009, 01:19:13 PM
by 4runner4x4
Last post Nov 30, 2015, 01:11:55 PM
by Kaos III%
Last post Dec 05, 2010, 05:15:36 PM
by IVrunner
Last post Feb 26, 2014, 07:05:11 AM
by mudmaster
Last post Jan 10, 2020, 08:14:52 AM
by clb
