Author Topic: Lock-Rite installation Help!!!  (Read 2096 times)
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
« on: Mar 12, 2010, 09:26:37 PM »
So i'm wanting to put my Lock-Rite in my rear 8.4 Third non TRD. 5.29's.  does anyone know where i can get a good writeup on this? i just want to know if its something i can do in my garage, or am i going to have to take it in to a shop. i can't setup gears my self . Thanks    :hammerhead:
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
Re: Lock-Rite installation Help!!!
« Reply #1 on: Mar 12, 2010, 11:54:59 PM »
well the lockrite u can do yourself.
its pretty much the same as an aussie and they are very easy.
83yota5960
  • Turtle Points: -20
  • Male Posts: 551
  • Member since Sep '09
« Reply #2 on: Mar 13, 2010, 08:33:17 PM »
it is very wasy to do i did my aussie it was simple not sure about lock rites but aussie came with a complete how to with pictures and everything
83 short bed yota 35's 5.29's 4.7 f-150's arb front aussie locker rear high steer ifs rear axle
83 short bed yota 31 a/t mild lift welded ifs rear axle
99 audi A4 as my new daily driver.
<MIKE> [OP]
  • Turtle Points: 41
  • Male Posts: 618
« Reply #3 on: Mar 15, 2010, 11:22:22 AM »
ok so the ring gear and carrier can stay inside the third and all i have to do is take out the spiders and install the locker?
1987 4runner
249:1
HDcruiser
  • Turtle Points: 10
  • Male Posts: 580
  • Member since Dec '06
« Reply #4 on: Mar 15, 2010, 11:30:07 AM »
If i remember right, i pulled the carrier out, removed the ring gear to get the spiders out, then installed the lock rite in where the spiders where. Its been at least 10 years since i've installed lockrites.. They are easy. It should come with instructions. I've installed about 3 for my friends along time ago.
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
« Reply #5 on: Mar 15, 2010, 12:44:56 PM »
Dude, go check out gearinstalls.com. Zuk has several setups with a luchbox locker.
<MIKE> [OP]
  • Turtle Points: 41
  • Male Posts: 618
« Reply #6 on: Mar 15, 2010, 12:48:49 PM »
ya i checked that out. but like i said i don't know how to set up my own gears. like the backlash. just wondering if i could install this with out having to do that. i have never gotten a straight answer.
1987 4runner
249:1
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #7 on: Mar 16, 2010, 09:41:54 PM »
If you have to pull the carrier out to install it you will have to re-set the backlash. Everything else will be fine because you are not messing with the pinion so the gear pattern should be the same. Back lash is not that hard to set-up but you do need a dial indicator and someway to hold it. Both can be sourced at Harbor Freight fairly cheap.
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Member since Aug '09
  • Not all who wander...are lost
« Reply #8 on: Mar 16, 2010, 09:49:20 PM »
this is a pretty good write up. its on a v6 8" diff though. Not a 8.4" but im guessin its pretty close if not the same.
http://yotatech.com/f116/lockright-locker-install-into-v6-rear-write-up-pics-179241/
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
Last post Aug 21, 2002, 03:24:42 PM
by BigMike
Last post Apr 22, 2005, 10:09:51 AM
by bluetoy84
Last post Mar 19, 2007, 01:29:08 PM
by TexJeff87
Last post Feb 28, 2010, 10:02:01 PM
by possume22
Last post Feb 09, 2011, 05:37:10 PM
by rick80
