Author Topic: engine cutting out  (Read 1719 times)
rustyboltz
  • Turtle Points: -2
  • Member since Nov '09
engine cutting out
« on: Mar 04, 2010, 03:49:30 PM »
My engine will cut out while it is ideling or when crusing down the road at a steady speed.  By cutting out i mean the engine will act like it is not firing on one cylinder.  I have checked all the vacuum lines, timing, changed the spark plugs and wires. I have checked the archives for past posts about a problem like this and because of it i have also checked the TPS and it is ok.  I have a 88 22R 4 speed tranny.  Any suggestions on what it could be?
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: engine cutting out
« Reply #1 on: Mar 04, 2010, 04:11:19 PM »
i am assuming it is a 22re?
22r doesnt have a tps, and there werent many carbs around in 88
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
« Reply #2 on: Mar 04, 2010, 04:21:41 PM »
fuel filter-fuel pump
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
SFD4x4
  • Turtle Points: 4
  • Male Posts: 218
  • Member since Mar '10
« Reply #3 on: Mar 04, 2010, 05:29:25 PM »
I would also change the fuel filter and check the pump.  I had the same problem, except mine would completely die.  I changed the filter and problem solved.
83 pickup, 4.88s, chevys in rear, RUF, Dual Transfers, flat belly, 3RZ swap, disc brake x4, rollin on 36" irocs
IF YOU SEE A 20' PAC WEST/CARSON FLAT BED TRAILER FOR SALE CHECK OUT THE STOLEN SECTION.  IT MIGHT BE MINE!!!!
rustyboltz [OP]
  • Turtle Points: -2
« Reply #4 on: Mar 05, 2010, 12:43:53 AM »
I do have the 22R because I have a carb.  I thought that I did have a tps.  I guess I need to check what the item on the side of the carb that I checked.  I did not think about the fuel filter.  I will change it today and see if that helps.
rustyboltz [OP]
  • Turtle Points: -2
« Reply #5 on: Mar 05, 2010, 02:58:06 PM »
I just changed the fuel filter and drove it for a while and it did not help.  The fuel filter did need to be replaced.  I dumped the fuel out of the filter and it was brown, like liquid dirt.
Last post Feb 10, 2004, 09:03:20 AM
by anthony1
Last post Jan 26, 2007, 12:29:00 AM
by fordh8r
Last post Jun 27, 2006, 09:34:25 AM
by Weldo
Last post Aug 24, 2006, 05:59:16 PM
by RABIDYOTA
Last post Apr 05, 2009, 06:30:19 PM
by hammer
