Author Topic: Clutch pedal is falling to the floorboard...  (Read 2454 times)
blackyoter416
  • Male Posts: 43
  • Member since Oct '08
« on: Mar 01, 2010, 11:48:41 AM »
The clutch pedal is falling to the floor if u press on it real softly and stays to the floor until you lift it back up n it doesn't engage the clutch when it does go to the floor, the only time is engages is when u push on the pedal quickly..
I thought bleeding the system would help but i just got done doin that n it didnt help at all but i did get a lot of air bubbles out.
 :dunno: anybody have any ideas??
90 std cab, 3.slow, short box bobbed 12", 85 front, hi-steer, hi-pinion, 529s, locked, 39.5 iroks, 5" marlin springs, bilsteins...
GNasty 82
  • Turtle Points: 994
  • Male Posts: 206
  • Member since Nov '09
  • Get Nasty!!!
Re: Clutch pedal is falling to the floorboard...
« Reply #1 on: Mar 01, 2010, 11:51:01 AM »
Get a second person to watch the slave cylinder as you push the pedal and watch for it to actuate.
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
blackyoter416 [OP]
  • Male Posts: 43
« Reply #2 on: Mar 01, 2010, 12:03:36 PM »
the slave cyl only actuates when u push on the clutch hard, but when the pedal is pushed soflty to the floor, the slave cyl doesnt move.
GNasty 82
  • Male Posts: 206
  • Get Nasty!!!
« Reply #3 on: Mar 01, 2010, 12:11:35 PM »
Sounds like it's time to rebuild the slave cylinder.  It's really easy and only costs around $10 - $15 at your nearest parts store.  That's where I would start.
  BFG 37" KM2s
  Propane Powered.
Build Thread:
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
« Reply #4 on: Mar 01, 2010, 04:07:57 PM »
Mine did the same thing. Its pry the clutch master cyl.
91 Toyota High pinions f&r.
Quick Draw
  • Male Posts: 250
  • Member since Feb '10
  • Her name is Doris.
« Reply #5 on: Mar 01, 2010, 04:22:23 PM »
Either the master or slave cylinder...  I'm not too sure how you can tell which one it is specifically, unless you have a spare for something.  Often times when the seals are blown and they don't effectively push fluid, it leaks out somewhere.  So I would say track down any leaks.  If there is fluid around either cylinder, then you know that one's the problem.
'80 Pickup, 5VZ-FE engine, A340F transmission, Marlin gear drive adapter, Dual Ultimate transfer cases, 5.29 gears, Detroit rear/Lockrite front locker, 37" Goodyear MTRs, XRC8 winch, custom tube bed and armor
blackyoter416 [OP]
  • Male Posts: 43
« Reply #6 on: Mar 01, 2010, 10:54:17 PM »
well its def not leakin anywhere, dont see anything n i have never had to top off the fluid. so i guess i'll start with slave cyl.
blackyoter416 [OP]
  • Male Posts: 43
« Reply #7 on: Mar 01, 2010, 10:54:45 PM »
any idea on how much a new or used one is??
DD85runner
  • Male Posts: 329
  • Member since Jun '08
« Reply #8 on: Mar 01, 2010, 11:39:00 PM »
theyre like $12 brand new. GNasty82 already said this...
85 4runner: 5.29s, duals with 4.7, ARB fr, detroit r, hi steer, bobbed 12"
89 4runner sr5: sold
98 prelude: DD
KRT
  • Turtle Points: -10
  • Member since Aug '09
« Reply #9 on: Mar 02, 2010, 10:05:53 AM »
Its the Master, my master failed and did the same thing yours is.
Buy the master from Marlin.
NorCal TTORA
89 PU SAS 37" Iroks
07 Taco
blackyoter416 [OP]
  • Male Posts: 43
actually he said that was to rebuild it... just called the dealer n they want $66 for the slave cyl $117 for the master...  :jawdrop: thats a lot. junk yard said $25. i'll probly try that first  :crossed:
blackyoter416 [OP]
  • Male Posts: 43
Just looked at marlin's n there slave cyl is only $29!! sounds like a deal to me im orderin tomorrow!
DD85runner
  • Male Posts: 329
i just bought the brand new slave for $12 and my friend just put a brand new master in for somewhere around $30. i'd never buy any parts from a dealer theyre just ripoffs
98 prelude: DD
DD85runner
  • Male Posts: 329
98 prelude: DD
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
If it's the master, you'll probably find that your carpeting is soaked with fluid.....
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
83yota5960
  • Turtle Points: -20
  • Male Posts: 551
  • Member since Sep '09
 blackyoter416
Where the flopp did you look refering to DD85runner i just replaced my slave and master, slave was 12 with core and master was 30 with core.
83 short bed yota 35's 5.29's 4.7 f-150's arb front aussie locker rear high steer ifs rear axle
83 short bed yota 31 a/t mild lift welded ifs rear axle
99 audi A4 as my new daily driver.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
You sure about that?
:yesnod:
nonwing
  • Member since May '09
Stay with the factory parts whenever possible!  You can buy the factory clutch master & slave cylinder new made by Aisin for about half of what the dealer charges.  The only diff. is the casting with Toyota symbol is ground off.
joeycool00
  • Male Posts: 315
  • Member since Mar '10
  • 3rd f.a.s.t yes i'm a Jar Head!and proud of it
definitely the master
swapped89
  • Turtle Points: 270
  • Male Posts: 1,221
  • Not all who wander...are lost
I had a problem similar to this and it was my clutch pedal backet. I had no leaks anywhere in the clutch's hydrolic system. When the bracing on the clutch pedal bracket fails, it feels like you get resistance somewhere but its just the metal bending.
I had to pull my bracket out (big awckward thing under the dash) bend it back to normal and weld it back up/brace it.
that hole on the left is where the clutch master cylinder comes through the firewall  :biggthumpup:
That might be yer problem.
I ended up replacing the master and slave cylinders before I figured that out.
SAS 89 p/u 3.0 5speed, bobbed, locked, ready to play in the rocks. or wherever the pavement ends :)
http://board.marlincrawler.com/index.php?topic=61345.0
a wise man listens and observes more so than he opens his mouth.. and when he does it is valuable information....   (twistedtoy92)
IMMUDDY
  • Turtle Points: 36
  • Male Posts: 329
  • Member since Jan '08
If I hit it just right, I might make it.
Last post Mar 11, 2003, 06:27:11 AM
by vikingsven
Last post Jan 20, 2006, 08:17:55 AM
by trax28to
Last post Jan 14, 2007, 05:47:19 PM
by Yota1
Last post Sep 12, 2008, 09:12:40 AM
by 83MT
Last post Nov 22, 2009, 07:12:39 PM
by emsvitil
