Author Topic: heater help  (Read 1141 times)
Jakesteads
  • Turtle Points: -19
  • Male Posts: 842
  • Member since Mar '07
  • It was Nice....
heater help
« on: Feb 20, 2010, 09:06:50 PM »
i have a 3.8 motor in my truck my blower turns on and blows strong... i hear the vents opening up and changing from vent to heat and ac.... but my heat is not hot.... what should i look for i have never messed with heat ever...
it seems as though the lines are hooked to the engine and run into the cab as well...
any advice would help
I like Toyota
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: heater help
« Reply #1 on: Feb 20, 2010, 11:17:33 PM »
Check and see if the valve on the firewall is opening. This valve controls the flow of coolant into the heater core. They sometimes rust closed so that even if you slide the lever to the hot side it will not open.
Jakesteads [OP]
  • Male Posts: 842
  • It was Nice....
Re: heater help
« Reply #2 on: Feb 21, 2010, 07:06:09 AM »
ok that sounds like a plan ive been researching and it looks like problem is normally that or a heater core being clogged
I like Toyota
Last post Apr 09, 2003, 08:15:33 AM
by Rock_Starr
Last post Nov 07, 2005, 08:26:08 PM
by h0nke
Last post Nov 26, 2007, 05:19:37 PM
by 93tonkatoy
Last post Dec 04, 2008, 06:29:53 PM
by 94MtnYote
Last post Mar 09, 2014, 01:59:48 PM
by R.DesJardin
