Author Topic: LCE Pro Fuel Injection Kit or Electromotive - Ignition Kit. i need info  (Read 2516 times)
tom85
  • Turtle Points: -14
  • Male Posts: 185
  • Member since Jan '07
  • toyotas dont get stuck they just stop to poss for
:) nothing worth wheeling other than a YOTA :)
zippo
  • Turtle Points: 550
  • Male Posts: 1,557
  • Member since Nov '08
    • oppiz.net
Call and talk to them, they can give you alot of info. Some are easy to install and work well, some are hard to tune and are hard to isntall "more for racing"
If you see it, its for sale.
tom85 [OP]
  • Male Posts: 185
yea it says its easy to tune and they have the instellation instructions for one of them and it doesnt look hard at all. i was just wondering if any one used either one
dezrik
  • Male Posts: 192
  • Member since Jul '09
Why not Use Toyota EFI Stuff, 89 EFI Setup hook up 5 wires and your done :shrug:
Tyler82toy
  • Male Posts: 81
  • Member since Jun '09
i actually am about to do the fuel injection for my 82 i called and talked to John in tech and he said that the best way to do it is to get kit number three because kits one and two dont come with the ignition and you would need to get a msd box and one of there distributors to run it but he said also that it is really easy to tune and you have a fine tune adjuster on the dash so if you are driving down the road and want better mileage you can lean it out some after talking to him i feel really good about buying it but it is a bit of money hope this helps
tom85 [OP]
  • Male Posts: 185
yea that does help.
see there is just a lot of stuff the ecu is reading a lot and it runs all right im just not happy with and every once and a while i get a check engine light that come on then goes off i cant figure out what it is
Tyler82toy
  • Male Posts: 81
so you already have injection? have you tried pulling the codes?
tom85 [OP]
  • Male Posts: 185
yes and yes it doesnt want to start right and when it does it runs fine the check ingine light dont come on for a while usally when i get up around 50 so i cant get the codes
Tyler82toy
  • Male Posts: 81
well then maybe it is a good way to go and the fact that it is programmable helps and from what ive read the factory computer puts a limit on power right at 125 so this is a bonus
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
i wanted to use the this kit http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=9E52F2AE-2740-4952-B018-950AD15C4B94
just dont have the money yet. i think there is one kit that lets you delete your mass air flow sensor, smog equiment, distrubiter and air box all gone. it would be sweet i think
tom85 [OP]
  • Male Posts: 185
yea the stage 3 has both kits in one just need new injectors that would be the way to go
tom85 [OP]
  • Male Posts: 185
they also recamend a fuel pump relay, map sensor and 8.5 mm wires so i pricesed every thing and it came out to $1937
88_Pathy
  • Turtle Points: 65
  • Male Posts: 1,251
  • Member since Oct '06
  • Raised suspension
For that price get a newer engine...
tom85 [OP]
  • Male Posts: 185
i have a brand new motor maybe get a newer recked truck with a 22re and pull the harness out
Last post Aug 22, 2003, 09:30:14 AM
by mhemingw7
Last post Sep 23, 2004, 11:40:06 AM
by BigMike
Last post Oct 25, 2005, 07:10:08 PM
by h0nke
Last post May 05, 2009, 06:18:22 PM
by Tallchevy
Last post Jun 28, 2009, 11:56:33 AM
by crawlerdad
