Author Topic: Help! No charge Issues!  (Read 2079 times)
chodycrawler
  • Male Posts: 27
  • Member since Feb '10
« on: Feb 15, 2010, 09:34:14 PM »
I really need some help figuring out why my truck isnt running. its a 1979 with a 20r. i let the truck sit for a while because i was doing some tranny work, i get back in to start it and it wont crank. so i jumped it. and it worked, until i took the jumper cables off, than the truck died. so i replaced the alternator. truck is still having the same issues. please help! any ideas would help! i already checked the fuses, and the engine fuse was blown, so i replaced it and nothing changed.
79 flatbed, 20r w/ weber, locked front and rear with lock-rites, 5.29's, 34" swampers, terafex shackles, yadda yadda yadda....
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: Help! No charge Issues!
« Reply #1 on: Feb 15, 2010, 10:27:19 PM »
Doesn't sound like you even needed to replace the alt, sounds like the battery is just too dead to stay running.  Your charging system won't recharge a battery if it's too far down and will still take a while if it's just a little down.  You need to stick it on a trickle charger for a few days or so and let it get a full charge, but don't forget to top off the water if it's a wet battery.
chodycrawler [OP]
  • Male Posts: 27
« Reply #2 on: Feb 16, 2010, 05:36:08 PM »
doesnt the engine not need a battery to run though?  :conf:
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #3 on: Sep 23, 2010, 08:51:39 PM »
no it does, it causes the sparkplugs to fire, and if you have a low battery you'll lose spark, i had it happen on the freeway, sucked very much so lol. but if your battery isn't dead then it's probably the little brain thing the alternator is wired to. i ended up ditching it and going gm 1 wire, works awesome.
Last post Mar 17, 2005, 06:21:25 PM
by YOguyDa
Last post Jul 27, 2005, 02:00:13 PM
by fellowsped
Last post Nov 21, 2006, 01:32:57 PM
by NeverEnough188
Last post Feb 22, 2010, 04:08:53 PM
by JoeShmo65
Last post Sep 20, 2011, 07:25:55 PM
by gtoyonrocks
