Author Topic: W56 output shaft+tail housing fit W59?  (Read 3571 times)
FXR UPR
  • Turtle Points: 11
  • Male Posts: 23
  • Member since Oct '03
  • Canadian Toyota Off-Road
    • www.6lug.com
« on: Nov 30, 2004, 03:58:30 PM »
Will this work?  I`m swapping a 2.7 into my truck (which has an auto) and I already have the w59 tranny that came with the motor.  My truck is am 85.  I`m planning on running dual t-cases and would like to fit this together some way.  I know marlin sells an adapter for this but I`m wondering if I can make it work without the adapter.
www.6lug.com  Canadian Toyota 4X4 and Off-Road.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
Re: W56 output shaft+tail housing fit W59?
« Reply #1 on: Dec 04, 2004, 09:54:12 AM »
    You can sell the W59 tranns and buy one thats an HD W56 from Marlin it will bolt directly to your W59 bell housing and then you won't have to worry about adapters for your t-case.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #2 on: Dec 06, 2004, 10:20:18 PM »
There are a number of issues............
The output shaft on the W59 is 26 spline and the trans has a reverse gear brake.
I have never done this conversion, however i recall speaking to a customer in so cal that said he made it work.
The mainshaft 5th speed output bearing would also have to be replaced a W56A, B, or C type bearing.
I have many W59's in stock so i could check this out for you if you were interested.
Marlin
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #3 on: Dec 07, 2004, 05:18:08 PM »
   Ya thats me, I made it work.
I dont know about the auto stuff  I do know that if you have a 2.7 that came with a W59 then you just keep the bell housing and the put in a W56. Now I have version B of the W56 tranns, maybe that has some say in what you are doing.
Marlin
  • Male Posts: 856
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #4 on: Dec 07, 2004, 11:16:08 PM »
TacoRunner, thanks for your help :beerchug:
I have helped a number of customers install W56's with dual cases behind 2.7's but still have not had to do change the tailhousing yet.
I still remember when you drove to my shop and i worked on your trans.
Marlin
TacoRunner
  • Male Posts: 2,324
    • 4wheelunderground
« Reply #5 on: Dec 08, 2004, 05:35:08 PM »
   Marlin,  Im totally blown away that you remeber that.    You just made my day!!!!! :thumbs:
FXR UPR [OP]
  • Turtle Points: 11
  • Male Posts: 23
    • www.6lug.com
« Reply #6 on: Dec 10, 2004, 07:37:00 AM »
Thaks for the replies.  I think in the long run a w56 wil be the best way to go.  Marlin, how moch $$$ toward a HD W56 would a w59+t-case be worth :idea:
Last post Apr 21, 2011, 02:36:45 PM
by yotaneck13
Last post Mar 12, 2021, 02:02:08 AM
by Knocks
Last post Jul 30, 2021, 04:50:48 PM
by 94toytruck
Last post May 02, 2022, 06:38:52 AM
by Gnarly4X
Last post Aug 01, 2023, 12:15:11 PM
by D2therick
