Author Topic: Odd V6 third member  (Read 2700 times)
NITE KRAWLERS
  • Turtle Points: -35
  • Male Posts: 970
  • Member since Oct '09
  • I KNOW A SWEENEY BRO!!!
Odd V6 third member
« on: Feb 14, 2010, 09:12:02 PM »
Hey has anyone heard of a V6 third member with 4.88 gears and the ring gear is thinner than normal and the housing is offset for the thinner gear.  :dunno: Its like a  :stopit:one of the bunch i think, like years 92 to 95 pickup/4 runner. Cause i got a set of 5.29's to put into and they will not work, cause the ring gear is bigger and the housing don't have the clearence for it. It wont go to the side to set down and mesh with the pinion gear. So if anyone has heard of this could ya let me know or give some input. I thought all V6 thirds in this year range were all mainly the same. Thankx for the help... :thumbs:
JOE 88
  • Member since Jan '09
Re: Odd V6 third member
« Reply #1 on: Feb 14, 2010, 09:40:09 PM »
i just put 5.29 in my 88 v6 third and i ran into the same problem all i had to do was grind out a little of the inside of the housing and i slipped right in.
88 pickup marlin SAS 5in spring ARB's F/R  Dual cases 35' BFG KM2 5.29
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #2 on: Feb 14, 2010, 09:47:31 PM »
The FACTORY 4.88 V6 diff is unique!
- Axle code G144, white pinion paint code,
- generally came in 92-95 trucks/4runners with V6, auto tranny, 31" tires, and tow package.
- Housing offsets pinion towards ring gear, allowing ring gear to be thinner
- OEM Toyota gears are the ONLY gears that fit this diff due to the thinner ring gear. All other gear sets have thicker ring gears and do not fit.
- The carrier (case) is the same as the V6 diffs, so normal V6 lockers, LSD's, etc. will work in this diff
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
« Reply #3 on: Feb 14, 2010, 11:14:28 PM »
im running them in my rig
tade you a stock v6 410 3rd for it
OOPS
  • Male Posts: 2,561
« Reply #4 on: Feb 15, 2010, 07:53:31 AM »
A lot of people are running them. The problem comes if you blow the gears, they are very costly to replace.
b4wheeler
  • Turtle Points: 137
  • Member since Jul '03
  • Annapolis, Md GO NAVY!!!!!!
« Reply #5 on: Feb 15, 2010, 04:28:55 PM »
I am running one in my truck.. they are actually getting hard to find..
You might be able to sell it and get enough out of it to buy a 4.10 v6 diff and make a few bucks...
92 Toy XtraCab, SAS, Dual Ultimate Marlin Crawler, 5.29s, ARB/front, Detroit/rear, Bobbed Bed, 36" IROKs, BudBuilt Xmember, Longfields, AP Chromo inners
88$Runner, Daily Driver, Working on it.......
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
  • Do You Know A Sweeney Bro?
« Reply #6 on: Feb 15, 2010, 05:05:42 PM »
do you guys know if a carrier out of a regular v6 third will fit into the stock 4:88 third and allow NITEKRAWLERS to run 5:29's?
97 4runner Limited
NITE KRAWLERS [OP]
  • Male Posts: 970
« Reply #7 on: Feb 15, 2010, 07:09:49 PM »
thanks man but I think my case is way different dude. I would have to grind out like a inch and still might not work.
NITE KRAWLERS [OP]
  • Male Posts: 970
« Reply #8 on: Feb 15, 2010, 07:27:24 PM »
thanks again man!
locktup
  • Turtle Points: 68
  • Male Posts: 1,146
  • Member since Jun '04
  • Locktup Fab
    • www.locktupfabrication.com
« Reply #9 on: Feb 19, 2010, 06:34:41 PM »
Here's a side by side of both.
Jason
www.LOCKTUPFABRICATION.com
dirty85yota
  • Member since Jan '06
« Reply #10 on: Feb 20, 2010, 04:33:24 PM »
wow those look weak, So I wouldn't want to run those? I was going to swap out my 4.30's for a set of them from 2 junk yard 1993 4runners.
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
« Reply #11 on: Feb 21, 2010, 08:00:29 AM »
I guess i have never heard of those breaking.  I have broken two ring gears and both times the teeth just break off.  It looks to me like the teeth are just as thick as the regular v6 ring gear, so you might not have any problems.
97 4runner Limited
locktup
  • Turtle Points: 68
  • Male Posts: 1,146
  • Locktup Fab
« Reply #12 on: Feb 21, 2010, 09:17:24 AM »
They allow more deflection.
Jason
NITE KRAWLERS [OP]
  • Male Posts: 970
« Reply #13 on: Feb 21, 2010, 07:55:49 PM »
thanks guys! I just got a set of 4 cylinder gears cause I have like 4 of the 3rd's laying around and are easy to get parts for plus I have never had a problem with the 4 cylinder or broke them! far as the 3rd member goes and if it can break I will do that. ha ha
Last post Jan 06, 2005, 06:25:49 PM
by Skinny_Pedal
Last post Dec 03, 2002, 02:41:27 PM
by chris672
Last post Jan 24, 2004, 07:54:14 AM
by toyrocs
Last post Jan 12, 2006, 12:07:05 AM
by futuretoyowner
Last post May 16, 2004, 08:50:17 PM
by Hyena
