im running them in my rigtade you a stock v6 410 3rd for it
i just put 5.29 in my 88 v6 third and i ran into the same problem all i had to do was grind out a little of the inside of the housing and i slipped right in.
The FACTORY 4.88 V6 diff is unique!- Axle code G144, white pinion paint code,- generally came in 92-95 trucks/4runners with V6, auto tranny, 31" tires, and tow package.- Housing offsets pinion towards ring gear, allowing ring gear to be thinner- OEM Toyota gears are the ONLY gears that fit this diff due to the thinner ring gear. All other gear sets have thicker ring gears and do not fit.- The carrier (case) is the same as the V6 diffs, so normal V6 lockers, LSD's, etc. will work in this diff
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
wow those look weak, So I wouldn't want to run those? I was going to swap out my 4.30's for a set of them from 2 junk yard 1993 4runners.
Started by J.D.Zuki Engine
Started by trt2 Parts Wanted
Started by medtro Parts Wanted
Started by 4RnrRick New Member Check-In!
Started by Hyena « 1 2 3 » New Member Check-In!
