Author Topic: no bright headlight sometimes  (Read 1490 times)
rustyboltz
  • Turtle Points: -2
  • Member since Nov '09
« on: Feb 06, 2010, 02:58:41 AM »
I have a 1988 base model pu with 22r 4 speed manual tranny.  I drive to work about 30 miles 6 days a week in the dark and when I go frim dim to brights on the headlights the headlights will go off until I shift back to dim.  This will happen for quite a bit until it all of a sudden starts to work.  I have reasearched the archives and found where people have cleaned the headlight switch in the steering column.  Is that my problem?
I would like to say that I appreciate everybodys postings because it sure helps me to keep my truck fixed up.
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
Re: no bright headlight sometimes
« Reply #1 on: Feb 06, 2010, 06:00:11 AM »
sounds like you found a good place to start. give that a shot then report back. :thumbs:
toyotacrawller
  • Member since Apr '09
« Reply #2 on: Feb 06, 2010, 06:04:19 AM »
i would say thats where the problem is.
austintaco
  • Male Posts: 36
  • Member since Jan '10
« Reply #3 on: Feb 06, 2010, 06:38:18 AM »
Yes, its in the column switch. 4crawler has a repair listed on his site, but I couldn't find it with a quick search. I had the same problem, bought a new headlight column thing and the problem is fixed. I looked at my old one, and saw how the contact points was worn down and could be fixed, but the newer one was in much better shape.
« Last Edit: Feb 06, 2010, 06:27:14 PM by austintaco »
-Jake-
  • Turtle Points: 9
  • Male Posts: 538
  • Member since Oct '09
« Reply #4 on: Feb 06, 2010, 08:53:36 AM »
my 87 had the same problem.  just take apart the column and clean up the contacts in there.  be careful there is a little tiny ball inside the lever housing that when you pull the roll pin there is a spring in there so be ready.  don't lose the ball cause it will suck major without it.
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
« Reply #5 on: Feb 06, 2010, 02:57:43 PM »
you'll need about 1/10th of a sheet of 400-600 grit sandpaper to slide back and forth to clean the crud between the contacts.  My high beams went from nothing to working after I fixed that lousy switch.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #6 on: Feb 06, 2010, 03:44:40 PM »
Put dielectic grease on the contacts once clean.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
rustyboltz [OP]
  • Turtle Points: -2
« Reply #7 on: Feb 07, 2010, 02:39:40 AM »
Thanks- Once the snow leaves and the warmer weather arrives I will rebuild the part.  Thanks for the input.
Last post Jan 02, 2004, 01:43:24 AM
by toyzilla
Last post Mar 04, 2005, 09:31:26 PM
by Yota4life
Last post Apr 27, 2005, 02:13:39 PM
by Wheelinwoodman
Last post Apr 05, 2007, 01:30:51 PM
by rude86
Last post Nov 22, 2007, 10:06:12 AM
by mudmaster
