Those are some huge welds!
The water temp doesn't actually carry water to the gauge it uses a shielded type (copper?) wire i believe (sort of like a choke cable)... The oil however does carry oil to the gauge, but I dont use that crappy plastic hose they supply with the gauges i use copper tubing and make sure you use a grommet in the firewall. i do however keep a small stock of repair parts and pipe plugs just in case there is a leak... Here is a question for everyone who has a mech oil gauge..... were did you tap into the supply... i took the plug out under the oil filter and left the stock location....
I'm still trying to decide what to put in the last hole. The unlabeled switches are open and the idiot lights are for my alternator and check engine light.
I had a truck once that showed overheating problems that had a mechanical water temp gauge(a more autometer). The problem turned out to be the gauge was not accurate. I have since heard from race guys that they ( the ones I talked to) never run mechanical water gauges because they are commonly not accurate.
Oil temp or vacuum( if it's not a 22R). Vacuum gauge on a 22R is more like an on/off indicator.....
For the oil pressure sending unit I just used the stock location. For the water temp, I fab'd up a section of pipe and installed it between the rad and the t-stat housing.Not exactly the cleanest way, but the t-stat housing really isn't all that thick. I ran all new wiring, making them separate from the oem system.
So where are you guys putting your Oil Pressure and Water Temperature sensors on the motor? Did you splice into the original wires for the dash? Did you have to drill and tap new threads for the sensor for each gauge?Also, do most gauges such as VDO and Auto Meter come with the sensor itself? Or do you have to buy it as and accessory?
If you unhook the stock oil pressure sending unit in favor of the aftermarket one, will you get a low oil pressure light on the dash? That is my only concern with doing that. I was thinking about installing a "T" fitting and keeping both sending units.Also with your water temp housing. I think they sell those at Summit, right?
Look the part up at rockauto..............
for you guys who have installed aftermarket gauges and removed the stock sending units. did it mess with the ecu and operation of the engine? im looking to do this for oil pressure and water temp since my cluster got fryed and i want more accurate readings. thanks in advance.
I just bought cheap gauges from auto zone. I have the expensive ones in my tow rig. I had a truck once that showed overheating problems that had a mechanical water temp gauge(a more autometer). The problem turned out to be the gauge was not accurate. I have since heard from race guys that they ( the ones I talked to) never run mechanical water gauges because they are commonly not accurate. I don't know but I run electric temp gauges and have not had a problem with them. I'm still trying to decide what to put in the last hole. The unlabeled switches are open and the idiot lights are for my alternator and check engine light.
Started by Brandon Parts For Sale
Started by KYOTA Parts For Sale
Started by josho General 4WD Discussion
Started by Skinny_Pedal Toyota Pickup/4Runner Tech 1979-95
Started by EarlKann Parts For Sale
